ISB
Old Jan 31, 2008 | 08:19 PM
gales73's Avatar
gales73
Default ISB
Is it possibleto use a Allison Transmission in the ISB cummins 24 valve5.9
Old Jan 31, 2008 | 10:03 PM
02cummins's Avatar
02cummins
Default RE: ISB
believe it is, and actually i was gonna start lookin into the same thing
Old Jan 31, 2008 | 10:13 PM
Drew's Avatar
Drew
Default RE: ISB
yup. . .you can. you just need to have an adapter plate since the bell houseing wont match up. the re-engineered alison 1000 GM has has a lower final drive ratio than the 48RE so your freeway speeds will be quite low.
Old Jan 31, 2008 | 10:19 PM
02cummins's Avatar
02cummins
Default RE: ISB
much stronger than my current auto ? 47re
Old Jan 31, 2008 | 10:29 PM
Drew's Avatar
Drew
Default RE: ISB
you would be better off money wise with a valve body, billet torque converter, and billet input shaft. there is some computer tweaking that has to go on for it to work with the Cummins. . .who knows what kind of computer adjustments would have to go on for a 2nd gen 24 valve.
Old Feb 1, 2008 | 09:32 AM
gales73's Avatar
gales73
Default RE: ISB
Well i am having problems with my stock tranny anyway so i am going to replace it..i think its ethier the torque converter isnt locking up right(not gettingenough pressure) or the first clutch is burnt out...[:@]and i want something that can take a hit and my father worked at allison for 17 years he just wasnt sure if it would work with the cummins...i have never messed with my trucks computer how hard is that...
