oil change
ORIGINAL: DBLR
you can’t always go by miles on the factory oil you also have to look and see how old the oil it is.
Well done !!
ORIGINAL: DBLR
If you want to go to longer oil change intervals then you need to get an oil by pass system installed and use high quality synthetic oil like Redline, Royal Purple or Amsoil like I use and take oil samples to be tested.
Does the manual say that it's OK to use synthetic ??
[sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif][sm=icon_rofl.gif]
Sorry ... I just had to ...
ORIGINAL: Mayfair
Actually, I'd love to have use the first image I found when searching for "flipping the bird" on the image search in google, but that might have got me banned, so I ended up using the second image.
Switching to synthetic depends on how you use your truck. You want the engine broke-in before switching. That could be anywhere between 15,000 and 30,000 miles. Shorter if you tow alot, longer if you don't work it that hard.
FYI- The dealer I bought mine from suggested 6000 mile oil change intervals because they disagreed with the service schedules as well. I usually try to target 5000-6000 miles with dino oil myself.
ORIGINAL: Mayfair
Absolutely !!
ORIGINAL: cujo
Best $25 you'll ever spend if you change your own oil.
After draining is complete, the secondary is removed and stored, and a convienent cap is screwed onto the primary fitting. All in all, the primary fitting along with the cap has a very low profile, and any thought of accidental draining or shearing off are minimized.
I have this on my ride and no probelms to speak of.
(I'm assuming I have Mayfair's endorsement on this?)
There's a reason its says "Resident Smart ***" below his name!!
I laughed.
I laughed.
ORIGINAL: Mayfair
ORIGINAL: minex
When can I start using synthetic oil? Also, how much more does it cost?
