DRUM ROLL PLEASE
Old Feb 20, 2008 | 09:54 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default DRUM ROLL PLEASE
after much frustration, and money to fix my ctd, I found a major problem and am 1/2 way through the fix for it.
breif.....replaced pcm, and crank sensor. went to Dodge and had mechanic run his ODB scanner on it. found a trans N safety switch code. he crawled bellow to look andtouched the harness causing an arc thus shutting down the engine. so, I brought it home to investigate possible miniscule nicked conductors.
OHH FRICKIN NO!!!!! [:@][sm=headbang.gif][sm=headbang.gif][sm=headbang.gif][sm=headbang.gif][sm=headbang.gif][sm=headbang.gif][sm=shootshoot.gif]
the neutral safety switch conductors, and the OD wire harness conductors had degraded to bare copper over a foot into the wire harness on top of the trans.....
this crap fell to pieces in my hands when I touched it.
I have removed the 5 conductors from the harness to the trans. fabricated new harness for the N safety switch and OD connectors..
will post pics when I am done.
this is a short break
Old Feb 20, 2008 | 09:56 PM
lilfroger's Avatar
lilfroger
Default RE: DRUM ROLL PLEASE
How many times did you zap yourself playing with the harness
Glad you're getting to the bottom of the problems...hopefully this will be the last of the issues that beast gives you for a while.
Old Feb 20, 2008 | 10:00 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: lilfroger
thanks for the vote of confidence there missy!
I removed the negative battery cable as you should when working on automobile electrical systems
Old Feb 20, 2008 | 10:09 PM
lilfroger's Avatar
lilfroger
You're the second person to call me "Missy" today.
I never get called girly names like that....must be the eclipse
Old Feb 20, 2008 | 10:29 PM
finny's Avatar
finny
well at least you know wut it is now.
Old Feb 20, 2008 | 10:55 PM
Parts/Service's Avatar
Parts/Service
Glad to see that you found a problem that you could actually see is a problem.
Old Feb 20, 2008 | 11:25 PM
Kev_n_AZ's Avatar
Kev_n_AZ
test drove and it all WORKS 5 x 5!!!! [sm=happybounce.gif]
OD engages around 52mph ..thats an adjustment. need to go back and adjust kick down to proper setting too.
pics soon!
Old Feb 20, 2008 | 11:27 PM
Parts/Service
[sm=bounceybounce.gif] wish you had of found this before you spent all that money, but live and learn...
Old Feb 20, 2008 | 11:30 PM
lilfroger's Avatar
lilfroger
WHO HOO!!!!
Old Feb 20, 2008 | 11:34 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Parts/Service
I am suspectinmg that a new PCM was in order anyways. with the two sensors litteraly shorting out (dead short) , the old pcm may have been shorted internally too.
even installed that new crank sensor yesterday
