guages
Old Mar 2, 2008 | 03:53 AM
finny's Avatar
finny
Default guages
i installed guages and my tranny temp is acting up it fluctuates from over 300 degrees to nothing. is this a bad probe? bad ground? taped into wrong wiere?
any help would help.
Old Mar 2, 2008 | 09:45 AM
steve05ram360's Avatar
steve05ram360
Default RE: guages
your tranny temp gauge should have it's own sensor, you can probe the wire and see if the value is fluctating, if it's not and the gauge is acting up at the time, then check your power & ground to the gauge. if those are good then it's your gauge being bad.
Old Mar 2, 2008 | 01:27 PM
finny's Avatar
finny
Default RE: guages
o the stock wiring was not long enought to reach my transmission so i had to extend the wire probly 2 feet could that have a effect?
Old Mar 2, 2008 | 01:59 PM
jakebrake's Avatar
jakebrake
Default RE: guages
Could be a bad connection either at the gauge our the sending unit. Is yours a one wire or two wire sending unit?
Old Mar 2, 2008 | 04:54 PM
finny's Avatar
finny
Default RE: guages
2 wire. your talking about coming from the probe right?
Old Mar 2, 2008 | 11:23 PM
jakebrake's Avatar
jakebrake
Default RE: guages
yeah, I would assume one of those wires has a bad connection or a break in it.
Old Mar 3, 2008 | 12:06 AM
finny's Avatar
finny
Default RE: guages
yah tomorow i will check my connections when i lengthend the wires.
