fleetguard filter vs baldwin filter
Old Mar 10, 2008 | 08:53 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default fleetguard filter vs baldwin filter
Marketing Bulletin
After extensive laboratory tests on four Baldwin fuel filter crosses compared to four OE first-fit Fleetguard
filters, results showed that the Baldwin filters
DO NOT meet Cummins specifications. The following two
tests used SAE standard procedures for accurate measurements as per Cummins specifications.
• The Single Pass Efficiency Test used SAE J1985 that measures the capability
of fuel filters to retain solid particles
• The Dust Capacity Test used SAE J905 that measures the capability of fuel
filters to hold fine test dust.
Only the Fleetguard filters met and exceeded OEM specifications. The following test results prove
why Fleetguard is the first-fit filter.
BF1212
BF957
Baldwin Does Not Meet Cummins Specifications:
Trust Only Fleetguard To Offer OEM Quality Filtration
20 micron
BF1212 92%
FS1212 96%
Cummins spec 96%
Dust Capacity Test
90 GPH
BF1212 23 gm
FS1212 23 gm
Cummins spec 22 gm
20 micron
BF957 94%
FF105 96%
Cummins spec 96%
Dust Capacity Test
90 GPH
BF957 14 gm
FF105 14 gm
Cummins spec 13 gm
MB2-02-1
©Fleetguard Inc.
Printed in the U.S.A.
BF1277
BF1274
SAE test procedures are very specific for heavy duty filtration. It is key that the proper fluid, dust, flow
rate, etc. be used correctly as per these procedures. Should these procedures not be followed, the results
become unrepeatable and irrelevant. Also, dust capacity results from different SAE tests cannot be
compared. It is common for many competitors to use automotive tests as opposed to heavy duty tests.
The same issue occurs with efficiency tests. Almost all of the major OEMs specify with a single pass
efficiency test. This is the most difficult test, since the filter only has one chance to catch the particle. In
contrast, some competitors use a multi-pass test, which gives the filter multiple opportunities to catch
particles. The same filter by single pass might be 98.7% efficient at 7 microns via single pass and 98.7%
efficient at 5 microns via multi-pass. Keep this in mind when comparing filters and reading test results.
For more information, call Customer Assistance
at
1-800-22FILTER (1-800-223-4583), fax 1-800-999-8664
or visit us at www.fleetguard.com 24 hours a day!
25 micron
BF1277 93%
FS1040 99%
Cummins spec 99%
Dust Capacity Test
150 GPH
BF1277 65 gm
FS1040 110 gm
Cummins spec 104 gm
10 micron
BF1274 69%
FS1007 99%
Cummins spec 99%
Dust Capacity Test
150 GPH
BF1274 61 gm
FS1007 110 gm
Cummins spec 104 gm
Old Mar 10, 2008 | 09:04 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
Default RE: fleetguard filter vs baldwin filter
Good find. I'm going to show that to a friend of mine who is a diesel mechanic. I think they switched their busses over to Baldwin filters a year or two ago.
[align=left] [/align]
Old Mar 10, 2008 | 09:15 PM
burban2002's Avatar
burban2002
Hmm that is something new. Over on another forum, it was stated that the baldwin filtered to a lower micron count. Good thing I stuck with the fleetguard.
Old Mar 10, 2008 | 09:25 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Jimmy and I are debating which brand is better between the two.
I called Fleetguard (Cummins) today for the specs on my fuel filter.
the fleetguard FS1232 fuel/ water seperator fuel filter for the 1st gen CTD is rated 20 micron filtration @ 96% efficiency.
North American Customer Assistance Center
Telephone (Toll Free):800-22FILTER (800-223-4583)
Telephone (Direct):931-526-9551
Fax:800-999-8664
Email:
fleetmaster.us@cummins.com
Address:
1200 Fleetguard Road
Cookeville, TN 38506
http://www.cumminsfiltration.com/en/...o_n_amer.shtml
Old Mar 11, 2008 | 01:11 AM
JimmyDiablo's Avatar
JimmyDiablo
I am sure that If I call Balwin they will tell me there filter is superior. Same with fram.
Old Mar 11, 2008 | 08:51 AM
BrianSudokhoi02
ORIGINAL: JimmyDiablo
Yea, Balwin will compare themselves to Fram and Fram will compare themselves to not using a filter at all.
Old Mar 11, 2008 | 01:08 PM
JimmyDiablo
Looks like kevin has a follower for the 20 micron club
Old Mar 11, 2008 | 03:00 PM
DBLR's Avatar
DBLR
Don't know much about the air filters but this is what I've read about the Fleetguard, Baldwin and a few other fuel filters:
The Fleetguard FS18000E is absolute at 7 microns (96% efficient at 5 microns) this is the OEM filter. Has a 14 gr. dirt holding capacity
Baldwin PF7977 is nominal at 1-2 microns and absolute at 5 microns, has a 24gr dirt holding capacity.
Donaldson lists P550785 is absolute at 10 microns.
The WIX 33585XE is nominal at 7 microns. 33585 is nominal at 10 microns.
Absolute is 98.7% efficiency and nominal is 50% efficiency.
Old Mar 11, 2008 | 07:11 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ok guys/ gals
which is smaller
1 micron or 20 micron?????
yes, I really would like your answer.
do we all know what a "micron" is??
Old Mar 11, 2008 | 07:28 PM
Drew's Avatar
Drew
having problems measuring up Kev. . .a little inadiquacy and feelings you dont quite meet thenorm???
