diesel kill switch
Old Mar 19, 2008 | 04:09 PM
Mayfair's Avatar
Mayfair
Default RE: diesel kill switch
You've still got me thinkkng abou the butterfly in front of the turbo thing. Blocking the air intake somehow would definately shut it down.
Old Mar 19, 2008 | 05:10 PM
mikebol's Avatar
mikebol
I'm not that much of a mechanic so this may be a stupid idea ...
Could you tap into the fuel line under the cab as it comes up the frame rail? Then use a synthetic rubber or even braded hose, run that up through the floorboard with a butterfly valve. That way you could turn the fuel on\off from within the cab.
Just a thought.
Mike
Old Mar 19, 2008 | 05:52 PM
Mayfair's Avatar
Mayfair
I think he already thought abou that Mike, but he doesn't want to run a fuel line into his cab ( which I don't blame him )
Old Mar 19, 2008 | 06:36 PM
Bass Hunter's Avatar
Bass Hunter
I think he meant to just put the handle of the valve in the cab with the fuel lines remaining under the truck
goose\'s Avatar
goose\
This is what i would install. Its a 2-wayelectric solenoid fuel cut off valve, you can cut the fuel supply by mounting a switch under your dash or something, and the valve is mounted somewhere on your fuel line and won't need to be plumbed into the cab. In the diagram they mounted a 3-way valve between the transfer pump and the injector pump that way when the valve was in the off position it would deliver the fuel from the transfer pump back to the fuel tank.
http://www.cei-italy.it/pdf/eg3.pdf
EG3 - DIESEL OIL FLOW ON/OFF 3 WAY SOLENOID VALVE FOR ENGINE STOP
[align=center][/align][align=center][/align]
http://www.directindustry.com/prod/c...218-54739.html
Old Mar 19, 2008 | 07:58 PM
mikebol's Avatar
mikebol
Hey, I never claimed to be the sharpest tool in the shed
What Goose has there looks very cool!
Mike
Old Mar 19, 2008 | 11:35 PM
JimmyDiablo's Avatar
JimmyDiablo
What about those removeable sterring wheels? I think Grant makes them.. corection Momo makes them
http://cgi.ebay.com/ebaymotors/New-m...QQcmdZViewItem
Old Mar 20, 2008 | 10:35 AM
macattack's Avatar
macattack
How about just pulling a few important fuses.
Old Mar 20, 2008 | 05:04 PM
Mayfair's Avatar
Mayfair
How about a battery switch like you see on hot rods?
Old Mar 20, 2008 | 06:11 PM
G0tMudd's Avatar
G0tMudd
how about you just remove the engine LOL, sorry just had to -_-
