NEED INSIGHT ASAP!
Old Mar 17, 2008 | 06:28 PM
Az2500Cummins08's Avatar
Az2500Cummins08
Default NEED INSIGHT ASAP!
I am going down to Houston on friday to pick up some 35 12.50 17 Pro Comp Xtreme A/T's. and I need to know if I can get them put on now or have to wait till later. I still don't have my shocks in to put my lift on, so will the 35's rub with my truck at stock height?
Old Mar 17, 2008 | 06:34 PM
dirtydodge02's Avatar
dirtydodge02
Default RE: NEED INSIGHT ASAP!
When I had my 1500 I had 35's check fit to my truck. At first they didn't fit, but after the leveling kit, they did, with minor rubbing. A 2500 should be able to take 35's like a champ at stock height. Just don't hit too many big bumps or potholes.
Old Mar 17, 2008 | 06:39 PM
ZmanTRX4's Avatar
ZmanTRX4
They'll fit. might rub at full lock but nothing that will hurt anything until you get the lift of there.
Old Mar 17, 2008 | 08:01 PM
Welder597's Avatar
Welder597
I've got 35's on mine now no lift and no rub.
Old Mar 17, 2008 | 08:12 PM
Az2500Cummins08
Are there any suspension or fender size differences between the 05 and the 06-08?
Old Mar 18, 2008 | 12:44 AM
JimmyDiablo's Avatar
JimmyDiablo
I say mount them, if they rub even a little bit, Call me and I will pick them up. I would not want to ruin those pretty black fenders on your truck. I will not even charge you a pick up fee.
Old Mar 18, 2008 | 07:43 AM
Tommygunz's Avatar
Tommygunz
You should be okay, I have got 35's on mine, different off set though, as mentioned before you might rub a tic at full lock
