Belt Screach fix
Old Mar 25, 2008 | 07:47 PM
silverbullettlwb04's Avatar
silverbullettlwb04
Default Belt Screach fix
Hello Everyone,
I'm new to DF... What can I do to fix that belt screach when you turn off your truck. 04 Dodge 2500. Thanks
Old Mar 25, 2008 | 08:03 PM
mopar1973man's Avatar
mopar1973man
Default RE: Belt Screach fix
Totally normal... It's called a power Chirp... [sm=shades.gif]
But if you want to get rid of it... Pour some pepsi on it. What will happen is the pepsi (or soda pop) will get sticky and make it quit...
Old Mar 25, 2008 | 08:19 PM
triton's Avatar
triton
you might want to check with your dealer too. Or maybe parts/service will chime in. I believe there's a TSB for that. Something about replacing the belt tentioner. Don't know what year trucks it was for though/
like mentioned though... it's the nature of the beast. There a lot of torque even when shuting down
Old Mar 25, 2008 | 08:28 PM
Drew's Avatar
Drew
if you want the technical answer of what is going on. . . the engine actually stops turning quicker than the acessories. this is where the chirp comes from. it only happens on auto's since the manuals have that heavy as heck flywheel to keep the engine rotating a touch longer.
Old Mar 25, 2008 | 08:55 PM
jakebrake's Avatar
jakebrake
Was wondering why the new truck didnt chirp, didnt think of that.
Old Mar 25, 2008 | 11:06 PM
Mayfair's Avatar
Mayfair
Looks like someone is getting pretty creative in Photoshop.
Old Mar 25, 2008 | 11:42 PM
justviper1's Avatar
justviper1
my 01 did this when i first bought it and it got annoying after a while. i put on a new belt and that took care of it.
Old Mar 25, 2008 | 11:54 PM
bekim's Avatar
bekim
It can only stop in one of six specific positions being the high compression motor it is. The corection it makes causes the belt chirp as it snaps to one of those positions. Sometimes it falls very close to one of those positions and the chirp is barely there, or not at all.It's totally normal!
Mike
Old Mar 26, 2008 | 12:24 AM
Parts/Service's Avatar
Parts/Service
Even if the dealer does this TSB, you may still have the chirp....DAVID
TSB # 09-004-06
Accessory Drive Belt Chirp At Shut Down
OVERVIEW:
This bulletin involves installing an overrunning clutch pulley on the generator.
MODELS:
2003 -2006 (DR/DH/D1) Ram Truck (Diesel)
NOTE: This bulletin applies to vehicles equipped with a Diesel Engine, sale code
ETH.
SYMPTOM/CONDITION:
A chirping sound maybe heard coming from the accessory drive belt when the engine is
shut down.
DIAGNOSIS:
If a customer indicates that the condition is present, perform the Repair Procedure.
PARTS REQUIRED:
Qty. Part No. Description
1 05183490AA Overrunning Clutch Pulley
Reimbursable within the provisions of the warranty
Old Mar 26, 2008 | 12:33 AM
jakebrake's Avatar
jakebrake
Actually I just finally got photoshop installed on my new pc and hada little freetime to make a new sig.
