Rough start / Sputtering
Old Apr 1, 2008 | 12:03 AM
htgriffith's Avatar
htgriffith
Default Rough start / Sputtering
When I first start up for the past two days my truck sputters. It seems like you have just changed the fuel filter type of sputter. I have not had awater in fuel light. I did open the drain a few times today just in case of some water. I already have PSD in my fuel. Once you start it up and get going it stops. I do not know if it is the lift pump or water in the fuel. I do have a tool box / fuel tank combo. I hope may be a little condensation was in it when I filled up last. I always fill up in the combo box due to it also is filtered giving my fuel two fuel filters to pass through. With that said I do not think it is trash. Plus I just changed my filters 900 miles ago. Any thought's??
Old Apr 1, 2008 | 08:09 AM
Drew's Avatar
Drew
Default RE: Rough start / Sputtering
try this. . .set the bully dog box to stock. . .drive it for a day, then return it back to what ever software load you used.
Old Apr 1, 2008 | 11:49 AM
htgriffith's Avatar
htgriffith
Drew, I have returned it to stock and will give it a try. What do you think is going on with that?
Old Apr 1, 2008 | 12:13 PM
Drew's Avatar
Drew
not real sure, I just remember seeing this was a possable solution.
Old Apr 2, 2008 | 07:50 AM
CowboyBob's Avatar
CowboyBob
It could also be air in the fuel line. If you have an aftermarket pump like a FASS or Walbro check the lines on the intake side of the pump.
