Drew and or Ty....
Old Apr 4, 2008 | 04:56 PM
savage.basher's Avatar
savage.basher
Default Drew and or Ty....
Hey guys, i was just talking to david parts/service about how I can recalibrate my speedo for the 37's. Apparently dealers can't do it with the scan tool. he said he thought that smarty's could go up to 37's?.. is this true. If it is, is it possible for a local guy near me who is using one to just loan it to me so i can change my speedo, or does the smarty have to stay plugged in for the speedometer fix to continue to work?
thanks!!
Old Apr 4, 2008 | 05:03 PM
mytowrig's Avatar
mytowrig
Default RE: Drew and or Ty....
if you can find someone with the right year, borrow it. once you load the program on and then take it off, it will leave your truck with the high idle enabled and also the correct tire size calib. and it will do up to a 42" tire with i think .10 increments. i know i'm not close (tx) and it will be a week before i am home, but if you cant find anybody by then, pm me
Old Apr 4, 2008 | 05:06 PM
Tommygunz's Avatar
Tommygunz
The Smarty is vin locked to the vehicle for that parameter, I already tried that... The speedo re-cal is tied into the ABS and that part of the smarty is vin locked
Old Apr 4, 2008 | 05:09 PM
mytowrig's Avatar
mytowrig
hmm... it worked on my buddy's truck.....[&:] but then i guess he added a superchips too. but his truck kept the high idle. and i currently have the stock setting on my truck and the speedo is still calibrated and i still have high idle...
Old Apr 4, 2008 | 05:19 PM
triton's Avatar
triton
If I'm not mistake, the Smarty will do up to 40" tires. It's only VIN locked when you have it loaded on a truck. As long as you return the truck to stcok... it will load on another truck. If you have access to a Smarty, you could try it. You don't even need to load a program as like mentioned, it's a part of the ABS which is a different system than the ECM. It should work.
If not, Superlift sells a stand alone re-calibrator.
Old Apr 4, 2008 | 05:21 PM
triton's Avatar
triton
BTW... with the programs Smarty has now... it would behove you to just buy one. You'll wonder why you never did before ! :-)
Old Apr 4, 2008 | 07:02 PM
MAB_CTD_4X4's Avatar
MAB_CTD_4X4
Savage sorry not to steal your thread but Triton any word on the 6.7 Smarty.
Old Apr 4, 2008 | 07:07 PM
energinerbuzzy's Avatar
energinerbuzzy
Yes it does work that way. I have put my truck back to stock several times and I have checked with the GPS and the tire calibration stays no matter what. The only way for it to change back is if you acually change it back your self.
This is also true for the high Idle feature. Once inabled, it also stays even if the truck is returned to stock.
Old Apr 4, 2008 | 07:11 PM
triton's Avatar
triton
ORIGINAL: MAB_CTD_4X4
It's in the works and suppose to be very soon, like this month or next. The 2nd gen guys got kinda left behind on the software updates so, they wanted to be sure they were happy before releasing the 6.7 software.
Old Apr 4, 2008 | 08:41 PM
Drew's Avatar
Drew
also word on the street is the revo tune should be out either next week or the week after. . .as things have been with smarty, that may take a month or two
