Stupid question about front end
I noticed this problem last night at work. I believe its the sway bar end links, but I'm not 100% sure. The driver's side has a few pin holes in it and was completely clean and dry. Its also starting to twist some. Can someone verify that this is the sway bar end links and does anyone know if there are upgrades over factor for this and if they're worth it?
Thanks
[IMG]local://upfiles/16793/4E9B92D5A2D9489C9B7B826A8935B141.jpg[/IMG]
[IMG]local://upfiles/16793/E68B824B03F84F99A238A9832FF0A9DE.jpg[/IMG]
edit: I added LSA to it last night to try and lube it.
Thanks
Its government gun lube. After some more research I found out this my happen with the KORE suspension because it allows more suspension travel. I think I'm going to get the KORE sway bay upgrade for it so it doesn't happen again. Thanks for verifying.
Trending Topics
If you want I think I have both my factory in the the tool box if you want them. Ill just ship them to you. They are off an 06 don't know what year yours is. But i know I won't need them if you want em-FREE!
