manual TC lock up switch
Old Apr 16, 2008 | 10:16 AM
justviper1's Avatar
justviper1
Default RE: manual TC lock up switch
in the post in diesel bombers it says that it is for 3rd gens. anyone know if this will work for 2nd gens?
Old Apr 16, 2008 | 12:31 PM
Scott91370's Avatar
Scott91370
So if you're really good you could take the signal wire from your speedo and bring it to the wire. When your speed reaches say 20mph the amount of power coming from the speedo wirewould be X-volts and activate the switch and when it under 20mph it would deactivate the switch.
Then you'd be set.
Old Apr 16, 2008 | 12:38 PM
dirtydodge02's Avatar
dirtydodge02
ORIGINAL: Batphreak
ORIGINAL: dirtydodge02
Ok, I understand what it does. My question is; Why? What purpose does it serve?
Puts more power to the ground in gears other than O/D. If the T/C is locked up the driveline is stiffer and much more efficient. Also in low-speed towing situations it should provide for lower tranny fluid temps since a non-locked T/C puts a lot of heat into the fluid. As the Demon points out you will do damage if you come to a stop with a locked T/C, it's like stopping with the clutch engaged.
So then does it not work in O/D?
And Scott makes an excellent point. Would that be possible?
Old Apr 16, 2008 | 01:24 PM
Batphreak's Avatar
Batphreak
Works just fine on 2nd gens, here are some schematic and info resources:
http://home.pacbell.net/jaybo/image2.gif
http://www.dodgeram.org/tech/mods/index.html
It does work in OD, I excluded it from my explanation because the computer automatically locks up the TC in overdrive anyway (no need for a switch in OD)
If one wasthat electronically profficientScott's idea should work great.
Old Apr 17, 2008 | 10:55 AM
Dallas192's Avatar
Dallas192
thanks for the info Bat, just what I was looking for............Dallas
Old Apr 18, 2008 | 11:49 PM
Twoforme2's Avatar
Twoforme2
I dont know why one could not build a latching circuit that was reset by the brakes.
So you would just hit a momentary pushbutton and it would latch in, then when you hit the brakes it would unlatch the circuit and no more locked TC. Obviously you would have to hit the button again if you were just slowing down, but it would be pretty foolproof so you dont forget and leave it locked when you come to a stop.
Seems fairly simple, without having to figure out anything about the speedometer
Old Apr 19, 2008 | 12:00 AM
dirtydodge02
Hmm... could you possibly tie it in with the cruise since the brakes will kill it?
