manual TC lock up switch
Old Apr 15, 2008 | 09:15 AM
Dallas192's Avatar
Dallas192
Default manual TC lock up switch
I am thinking of putting in a manual switch for my TC lockup, anybody have any info on how to do it?........99 CTD 4x4 47re.........Dallas
Old Apr 15, 2008 | 10:34 AM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: manual TC lock up switch
here ya go this should get ya started
http://www.dieselbombers.com/cummins...al-lockup.html
Old Apr 15, 2008 | 03:04 PM
Dallas192's Avatar
Dallas192
Thanks GRI, thats what I was looking for.........Dallas
Scott91370's Avatar
Scott91370
What would be the advantages/disadvantages of manually locking the TC?
I know 2 things about the auto tranny- when it works and when it doesn't.
Old Apr 15, 2008 | 03:10 PM
Dallas192's Avatar
Dallas192
when you let off the throttle the TC unlocks and then when back on the throttle it locks up again.....eliminates unwanted wear on the TC,......Dallas
Old Apr 15, 2008 | 05:00 PM
DieselDemon's Avatar
DieselDemon
ORIGINAL: Dallas192
Tell ya what my friend, you need to know what your doing with that switch. If you were to come to a stop and not shut that switch off, it would instantly snap something in the drive line, guaranteed. Somewhere between the flexplate and tranny inputshaft I would think. If it shears the splines inside the torque converter,you're done for...lol.
Not being a ball buster or wise guy at all. Just saying that once you install that, you driving habits will change. And in an instant you can do some heavy damage, my friend.
Good luck with your ride.
Old Apr 15, 2008 | 05:20 PM
Mayfair's Avatar
Mayfair
ORIGINAL: DieselDemon
Since when ??
Old Apr 15, 2008 | 09:56 PM
Dallas192's Avatar
Dallas192
I totally agree with you Demon, I would only use it on the highway or when I"m on a long straight away....just dont have the money right now for the ATS copilot........Dallas
Old Apr 15, 2008 | 11:37 PM
dirtydodge02's Avatar
dirtydodge02
Ok, I understand what it does. My question is; Why? What purpose does it serve?
Old Apr 16, 2008 | 08:58 AM
Batphreak's Avatar
Batphreak
ORIGINAL: dirtydodge02
Puts more power to the ground in gears other than O/D. If the T/C is locked up the driveline is stiffer and much more efficient. Also in low-speed towing situations it should provide for lower tranny fluid temps since a non-locked T/C puts a lot of heat into the fluid. As the Demon points out you will do damage if you come to a stop with a locked T/C, it's like stopping with the clutch engaged.
