thing to do
Old Apr 19, 2008 | 08:31 PM
burban2002's Avatar
burban2002
Default RE: thing to do
that its working? If its hunting and switching between 2 gears a lot, check your grounds on the batteries.
Old Apr 19, 2008 | 08:45 PM
Ketchup's Avatar
Ketchup
one was lose
Old Apr 19, 2008 | 09:08 PM
Ketchup's Avatar
Ketchup
is the truck suppose to take off slow is see all the other pull off good
Old Apr 19, 2008 | 09:11 PM
dirtydodge02's Avatar
dirtydodge02
Might not be breathing very well. You check the air filter? Maybe bad spooling in the turbo? Dirty injectors? Could even be the gearing.
Old Apr 19, 2008 | 09:24 PM
Ketchup's Avatar
Ketchup
what do u mean about the gearing. and how do i clean the injectors
Old Apr 19, 2008 | 09:30 PM
4x4fantasy's Avatar
4x4fantasy
Rear end gearing. A lower number usually results in slower acceleration, a higher number gives better acceleration.
Old Apr 19, 2008 | 09:55 PM
Ketchup's Avatar
Ketchup
i have a 3.55 do i need to get a 4.10
Old Apr 19, 2008 | 09:59 PM
4x4fantasy's Avatar
4x4fantasy
It would certainly help, but you will need to readjust your speedometer if you change the rear gear. Or you can run a larger tire to offset the difference.
Old Apr 19, 2008 | 10:11 PM
Ketchup's Avatar
Ketchup
i swich the rearend in my 1500 and i dont think that it change the speedo. but if it is because it is big jump then i understand.
what would happen if i pull off the cat and the other thing that i cant spell
Old Apr 19, 2008 | 10:13 PM
4x4fantasy's Avatar
4x4fantasy
It would get louder, and be illegal according to our government rules (which nobody gives a damn about anyway, lol). What other thing are you referring to?
