Got my Aero Installed...
#21
Is there any advantage to expanding the exhaust and installing the 5" aero compared to the 4"? I think it would look cool but I don't want to just be wasting money for looks. Also, I've beenconsidering the option of thenbringing the 5" exhaust out to the side in front of the duallies to eliminate the flow restrictions and fit problems from all the bends needed to get over the axle. As long as the hot exhaust gases don't hit the tires is there anything else to worry about with this set up?
Don
Don
#23
I wish I'd left stock exhaust on until I learned more about what's out there. I went with4" mbrp catback a long time ago. I recently deleted the cat and was expecting some more noise butreally wasn't much increase in that.Knowing what I know now if I had things to do over I would've left the stock exhaust pipes on there deleted the stock muffand cat then put an aero in + a cool tip... The mbrp looks good and sounds ok but not really what I want. You live and learn.. hopefully someone won't make the same mistake I did..
#24
