install a pryometer
RE: install a pryometer
Obi,
According the EdgeProducts http://www.edgeproducts.com/product_...manual-147.pdf
Highest you want EGT's to go is 1350 degrees max, when I drilled my sensor, I ran a shopvac while drilling/tapping to catch the shavings. Edge says to run the truck at idle for 10-15 seconds to remove remaining shavings.
Good luck!
Good luck!
Also run a small pocoket magnet into the manifold and sweep around to remove any shavings. I applied very light pressure while drilling to keep the shavings small. Get a quallity tap and coat it with grease so the shavings stick to it. Use the vaccum and magnet. Idle for a few minutes before driving.
it is also best to do it on a cold engine. that way any particles that are left in the manifold wont damage the turbo.
when I did mine I used the thickest grease I could find and stopped often to clean the bit and apply new.
I did the same with the tap. back it out often and clean it good.
We need to stop talking about Toyotas and photoshopping fat chicks and help the new guys out! Geez this IS A CUMMINS forum isn't it?
OBI, you can start with this thread. Cumminalong did a good job comparing the different ways to drill and tap a pyrometer. Just click the link below.
https://dodgeforum.com/m_710666/tm.htm
Trending Topics
