Drews Brew
Old May 5, 2008 | 10:27 PM
Buford445's Avatar
Buford445
Default Drews Brew
Started using Da Brew today, with new truck doint how its been taken care of ,so i changed oil,oil filter, fuel filter , and air filter,soI wanted to start with brew .
when i changed the oil it was black, and so was the fuel filter, is this normal ?
Old May 5, 2008 | 10:46 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
Default RE: Drews Brew
ORIGINAL: Buford445
Yes, and Yes. The oil will look very black even after a few hundred miles. The fuel filter will show a fair amount of black in the pleats. It will look kinda spotty. If it's solid black it is definatly time to change it.
Old May 5, 2008 | 10:57 PM
Buford445's Avatar
Buford445
Would like to change to amsoil , thought i would change oil with shell rotella one more time first, is there any problem with changing to synthic with 46000 mile ?
Old May 6, 2008 | 05:14 AM
cumminalong's Avatar
cumminalong
ORIGINAL: Buford445
Nope, you're fine. I'd run one more batch of dino through it for 1000 miles or so, jsut to get any residual garbage and then put the synthetic in.
And yes, the oil will be black almost as soon as you change it. If you start it, go around the block, come back and check it, it wil be black.
And, like mentioned above, the fuel filter will look spotty. Change it every 10K and you'll be good to go.
Old May 6, 2008 | 08:35 AM
12valveman's Avatar
12valveman
hey guys sorry to have to ask this but what the heck is drews brew? just wanted to know thanks guys
Old May 6, 2008 | 08:58 AM
cumminalong
ORIGINAL: 12valveman
Mix of Power Service Diesel Kleen (PSD) and either Marvel Mystery Oil (MMO) or 2 stroke oil. Named oafter our very own Drew.
In each tank I usually put 16 oz of 2 stroke and 16 oz of PSD. Everybody seems to have their own mixture.
The engine is noticeably quieter, smoother idle and decreased smoke output.
Old May 6, 2008 | 10:47 AM
DBLR's Avatar
DBLR
The best fuel filter to use is a Baldwin PF 7977, its nominal at 2 microns and absolute at 5 microns) and if you cant get one then get the Fleetguard Stratapore FS19856 is nominal at 5 microns and 96% efficient at 7 microns. Don't let anyone sell you a 10 micron fuel filter ( in june of 2006 Cummins wanted all 2003 and up engines to use a 7 micron fuel filter) as some places still sell them like, Wix 33585 is nominal at 10 microns, Wix 33585XE is nominal at 7 microns, Donaldson P550785 is absolute at 10 microns. The smaller the number the better it filters. FYI, Absolute is 98.7% efficiency and nominal is 50% efficiency.
Old May 6, 2008 | 11:24 AM
steve05ram360's Avatar
steve05ram360
ORIGINAL: Buford445
I've been running it since about 35k... word of caution... if you plan to run it long duration >7500 miles, get the oil sampling done, had an issue with mine where the oil did not last much past 10 and had to flush the motor to clean it out. One thing to mention here was the frequency of the off roading during that period... lots of it. not sure if that had anything to do with it or not but thought I should mention it.
also, gives me approx .75 mpg better IMO (there is a mpg thread in my sig with all the data).
Old May 6, 2008 | 02:59 PM
Buford445's Avatar
Buford445
Thankx I need all the advice i can get, I'm getting 15mpg & 20mpg i want to do all the rearends & trnsfr case with amsoil also, a friend of mine (that use to be dodge mech.) said to wait on the amsoil in the trany
Old May 7, 2008 | 09:34 AM
DBLR's Avatar
DBLR
ORIGINAL: Buford445
Did he say why to wait on the Amsoil ATF in the trans? I put Amsoil in mine when I did my first serviced it at 10K. So far with Amsoil and Mopar fluid mixed I've not had any problems from it in the past 14K that the 2 fluid have been mixed.
