AC Belower Help!!!
Old May 9, 2008 | 02:02 PM
SC Willie's Avatar
SC Willie
Default AC Belower Help!!!
06 Ram 2500 4x4 Crew Cab..............Ac is not blowing like it should. It blows out the dash vents and still blows out the floor. (This when it's in the dans vent position.) Defroster and floor is fine. Anybody had the same issue? The other day the blower motor made some noise (a vibration) then it stopped. It still blows and make a lot of air noise behind the glove box but is not blowing hard enough to cool me off.
Old May 9, 2008 | 03:53 PM
Mayfair's Avatar
Mayfair
Default RE: AC Belower Help!!!
Which model ram do you have again? I know there were reported problems with the blend door.
Old May 9, 2008 | 04:19 PM
SC Willie's Avatar
SC Willie
I'm not sure what you mean by model.
It's a 2006 Dodge SLT Ram Crew Cab 2500 4X4.
Old May 9, 2008 | 04:52 PM
energinerbuzzy's Avatar
energinerbuzzy
Don't feel alone, I am taking mine to the shop also for A/C problems. Mine takes forever to switch from dash vents to defrost. And it does not cool very well at all. If it's 80f outside and I get in to drive home, it takes about 15 minutes to cool the cab down. And when I stop and go in traffic, the vents will blow hot air every time I take off for a few seconds.
Old May 9, 2008 | 04:54 PM
trbodiesel's Avatar
trbodiesel
my 06 had that problem.. it was the blend vent that broke.. the dash had to be removed and the vent was replaced. i had to leave it overnight but it was covered under warranty.. the mechanic said there was no motor stop on the part at the time causing the vent to be torgued to far.. i think the new parts have that corrected.
Old Jun 12, 2008 | 06:19 PM
ntc09's Avatar
ntc09
Got the exact same problem on mine. 06 Mega Cab. Calling tomorrow to make an appointment. Hopefully get in it on Monday to be fixed.
Old Jun 12, 2008 | 06:37 PM
Az2500Cummins08's Avatar
Az2500Cummins08
Same problems here. POS. Blows hard, makes alot of noise, hardly blows at all, and takes forever to switch.
Old Jun 16, 2008 | 10:27 AM
stevew's Avatar
stevew
"insert exactly what AZ2500 said" That's my problem , going to dealer Friday
