Trouble code trouble?P0192 and P0483
Old May 15, 2008 | 07:31 PM
sallyman1's Avatar
sallyman1
Default Trouble code trouble?P0192 and P0483
Im in a bind. i want to go camping tommorrow with my truck(pull trailer). Its throwing these 2 codes when i cycle key. engine light came on and truck died. i was able to fire it up again and drive it home. it seems to work ok yet but engine light stays on. whats up any1 encounter these 2 codes?[/align]
Old May 15, 2008 | 08:33 PM
htgriffith's Avatar
htgriffith
Default RE: Trouble code trouble?P0192 and P0483
What are the codes????????????????????????????
Old May 15, 2008 | 08:40 PM
NickBeek's Avatar
NickBeek
P0192 = Fuel Pressure sensor too low. P0483 = Fan speed. Do you have any mods on the truck? I had the P0192when I had a bad connection on my Quadzilla box one time. As for the fan speed issue, check the wires going to the engine fan. I have read a few posts where they get pulled apart. Good luck and keep us posted.
Old May 15, 2008 | 10:58 PM
sallyman1's Avatar
sallyman1
i floored truck on setting 3 (juice) with fuel additve. Removed battery connectors for 30 minutes. start truck everything good now.
Old May 15, 2008 | 11:55 PM
austin's Avatar
austin
I had the fan issue... Be carefull, the next day the fan died and the truck was overheating bad if I wasn't on the highway. Just make sure it works still!
-Austin
