Glue removal?!?!
Old May 16, 2008 | 03:52 PM
energinerbuzzy's Avatar
energinerbuzzy
Default Glue removal?!?!
Ok so I took the Rig off the beaten path last monday down to the river. Somewhere along the way, it seems that I ran over a container of some kind of glue. Like floor glue or something. It is white, thick like caulk and get it on your hands and your screwed. I can not find anything to remove this crap.
it must have been a gallon can of it and it's all over the inside rear fenderwell, fender flare, side of truck and all inside the tire treads.
I have tried WD-40, goo off, mineral spirits, alchohol, diesel, gasoline, ect. About the only thing I havent tried is Acetone, I am scared to touch anything with that stuff!!
Anyone have any idea's?
Old May 16, 2008 | 03:53 PM
lilfroger's Avatar
lilfroger
Default RE: Glue removal?!?!
3M adhesive remover maybe?
Old May 16, 2008 | 04:52 PM
mytowrig's Avatar
mytowrig
high temp pressure washer?
Old May 16, 2008 | 05:04 PM
kp1095's Avatar
kp1095
the best thing to use is 'Goof Off', you can pick it up at any paint/hardware store. I had some resin based mastic on my suede seats and it took that off w/out any ill effects.
K
Old May 16, 2008 | 05:24 PM
Hauler6's Avatar
Hauler6
Lacquer thinner?
Old May 16, 2008 | 10:20 PM
firemedic740's Avatar
firemedic740
Im with lilfrogger on this the 3m adhesive remover takes alot of stuff off. I wouldn't do the acetone, and goof off contains acetone by the way- heard its not good on the paint.
Old May 16, 2008 | 10:34 PM
solarwarp's Avatar
solarwarp
It sounds like it might beteflon lithiumgrease if it hasn't set up yet.
Water makes it worse.
Old May 20, 2008 | 08:18 AM
stevew's Avatar
stevew
I have used acetone on my truck, when I debadged. Just be carefull and make sure you wax or polish after you clean the truck. Oh and make sure you do it outside, in case you want to be able to reador write in a few days.
Old May 20, 2008 | 12:34 PM
olddodge's Avatar
olddodge
Long shot but I use hand cleaner to get alot of stuff off that nothing else does.
Old May 20, 2008 | 01:19 PM
Kev_n_AZ's Avatar
Kev_n_AZ
I am on phone with a paint and body shop..they say you have to try different chemicals. last resort is SAND AND PAINT [:@]
if you can identify the substance, then look at its MSDS, call home depot, etc...
I suggest to try denatured alcohol.
btw...I just happen to be yakin to my sis who is asst mgr of a body and paint shop in CA when I saw this thread.
