Firemedic740- DPF Delete plans
Old May 26, 2008 | 05:23 PM
Az2500Cummins08's Avatar
Az2500Cummins08
Default Firemedic740- DPF Delete plans
Hey Firemedic- do you have any plans as to what you did with all those probes and lines and wires running into the DPF an Cat? What did you do with them all?
Old May 26, 2008 | 06:34 PM
firemedic740's Avatar
firemedic740
Default RE: Firemedic740- DPF Delete plans
Now everything is gone but the o2 sensors. The three harnesses for the old egt probes are now pluggedeinto the fooler box and the pressure tubes were removed. That is with the h&s kit.
Old May 26, 2008 | 06:36 PM
firemedic740
AZ, Are you gonna cut that crap off?
Old May 26, 2008 | 06:56 PM
Az2500Cummins08
Yes. I am going on vacation next month, and then after I get back, its all coming off.
Old May 26, 2008 | 07:01 PM
Az2500Cummins08
I am going to change the registration address from my dads house in the burbs to by buddies house out in the desert.
Old May 26, 2008 | 07:06 PM
Az2500Cummins08
Do you have a link to the H & S kit? I cant seem to find it online. What is this "control box" I am reading about? I was reading up on the BAPD and I want to replace the downpipe as well. My ultimate goal here is Mileage. I know I will never see what the 12 valves get, but I want al least 20 MPG. I can definetly feel the difference when the engine goes into regen.
Old May 26, 2008 | 08:53 PM
firemedic740
The fooler box somehow tricks the trucks computer from going into regen mode. Mine hasn't gone into regen mode since it was installed. I did the 4" turbo back they also have 5" turbo back. Here is the site
http://www.performancedieselinc.com/...elete-kit.aspx
Don't forget you will still have to have the edge w/ attitude to clear cel's on startup.
Old May 26, 2008 | 09:01 PM
Az2500Cummins08
Boy thats a hell of alot cheaper than the BAPD. I dont really need stainless anyways.
Old May 26, 2008 | 09:18 PM
jimmyshortz's Avatar
jimmyshortz
To what extent would this void your warranty- just warranty on exhaust or the whole engine/drivetrain warranty?
Old May 26, 2008 | 10:05 PM
Az2500Cummins08
I think it would most likely be the whole engine. That is a good point though. Hopefully the Parts/Service guy will see this....
