exhaust manifold/ r they worth it
Old Jun 1, 2008 | 05:08 PM
tigzgz's Avatar
tigzgz
Default exhaust manifold/ r they worth it
Hay guys,
Just had installed the Garrett stage 3 turbo. The eta's are a little warm. Would installing a banks exhaust manifold help?? The truck has a CFM intake, 120 horse injectors, K&N airfilter and 40-120 horse Edge box and fass fuel pump. The truck is running about 600-750 degrees on the pyro meter. Any suggestions??
Old Jun 1, 2008 | 05:10 PM
refloyd's Avatar
refloyd
Default RE: exhaust manifold/ r they worth it
if the pyro is pre-turbo then 600-750 is not hot at all. Try 1250-1350, now that is hot.
Old Jun 1, 2008 | 09:38 PM
cumminalong's Avatar
cumminalong
Brotha, I run that temp on a slight incline.......
You can run 1250 all day long and have no issues.
1350or sois where you have to start worrying.
Even at a short burst, 1400-1450 isn't gonna hurt it.
The only way you will drop temps is either 1 - Bigger intercooler, 2 - Nitrous, 3 - Water injection 4 - Twins, or 5 - Less fuel.
Old Jun 3, 2008 | 07:43 PM
tigzgz's Avatar
tigzgz
Thank you guys!!!!!!
I wont worry about it then. I'll spend the money on something else.
