Problem
Old Jun 10, 2008 | 01:13 AM
beachmstr's Avatar
beachmstr
Default Problem
So my brother has an '01 Cummins. He hauled a load today and got home and was leaking diesel. When he went to move it, it started very hard. When we went to move it later, it wouldn't start.
Old Jun 10, 2008 | 01:14 AM
beachmstr's Avatar
beachmstr
Default RE: Problem
Fuel was leaked all over the fender walls and underside of the body. Any ideas? Full Pump maybe?
Old Jun 10, 2008 | 01:22 AM
Little Foot's Avatar
Little Foot
Default RE: Problem
What about the o ring on the fuel canister on the last filter change did it possibly not get seated correctly resulting in a pinch, or maybe the valve is leaking draining the fuel reservoir. my $0.02. Hopefully it is something that easy.
Old Jun 10, 2008 | 05:53 AM
woligator's Avatar
woligator
Default RE: Problem
well its leaking so air got into the line that why it doesnt start,find the leak,fix it,blew the line and start engine
Old Jun 10, 2008 | 06:05 AM
behindbars's Avatar
behindbars
Default RE: Problem
Wasn't there a particular fuel line that had a tendency to blow on the 24v's?
Old Jun 10, 2008 | 06:44 AM
cumminalong's Avatar
cumminalong
Default RE: Problem
If it's all over the place, then it's AT or AFTER the injection pump. The high pressure is what sprays is. Check the HP fuel lines and the pump. If it was just one line, the truck should run, it would just miss fire.
Old Jun 10, 2008 | 07:13 AM
woligator's Avatar
woligator
Default RE: Problem
yeah cumminalong it will run but will be hard to start as air will enter the lines if its the pump supply line
Old Jun 10, 2008 | 07:33 AM
cumminalong
Default RE: Problem
Right....that`s what I mean. It'll run, but will hard start and miss fire and fuel will spray. From the sounds of it, its a line. Probably let air in back to the pump and now needs to be primed.
Old Jun 10, 2008 | 12:07 PM
CowboyBob's Avatar
CowboyBob
Default RE: Problem
Yeah a hard start usually means air in the line. That is what happened to me when I thought my VP44 was dying.
Old Jun 11, 2008 | 01:11 AM
beachmstr's Avatar
beachmstr
Default RE: Problem
I'll let you know what they say. He towed it to the shop since neither one of us can spare any time to fix it right now.
