air conditioning
Old Jun 11, 2008 | 07:44 AM
stevew's Avatar
stevew
Default air conditioning
First summer with the mega cab, it was 96 yesterday, after work I started the truck, turn the air on, and fan on speed 4. About 20 miles down the road the truck had cooled about 10 degrees.
Old Jun 11, 2008 | 07:49 AM
stevew's Avatar
stevew
Default RE: air conditioning
these pretzels are making me thirsty....I had alot more typed ...but well...you know
Old Jun 11, 2008 | 07:52 AM
stevew's Avatar
stevew
anyway its loud, doesnt blow hard, 06 with 32k
Old Jun 11, 2008 | 08:00 AM
Little Foot's Avatar
Little Foot
there is an airbox tsb if you are under 36000 they replace the whole unit mine was done at 24000
Old Jun 11, 2008 | 08:05 AM
stevew's Avatar
stevew
Did the airbox replacment help the AC? Is this common?
Old Jun 11, 2008 | 08:10 AM
Little Foot
My AC wasn't switching locations. I was only getting air out of the defrost vents so the truck took a horribly long time to cool. the fan speed was selectible. Does that sound about right?
Old Jun 11, 2008 | 08:30 AM
NickBeek's Avatar
NickBeek
My A/C checked out "OK" but I am not impressed. It does take too long to cool the truck, and if I am in stop and go city type traffic I can forget cooling off much. Steady driving at speeds over 35 or so will give barely acceptable cooling. I am going to put a coolant shut off valve in line with the heater core to remove that heat source from the cab, that netted me a good result with my '04 Ferd.
Old Jun 11, 2008 | 08:34 AM
stevew's Avatar
stevew
Im getting air from the dash vents but the pressure is low, when the fan is switched from 3 to 4 it sound like a boing under the passenger dash holding the brake.
Old Jun 11, 2008 | 08:37 AM
stevew's Avatar
stevew
Like nick said it takes my truck like 30 miles to get even close to comfortable.
Old Jun 11, 2008 | 08:45 AM
Little Foot
under the glove box with there is a rod that may be hung up try to free this if it cycles then that is the problem. My ac tested good as far as charge and pressures high vs low. The vents had very low presure, but the top vents higher pressure. Mine was doing this on a day with tempts of 115 I drove 30 miles to the dealer ship that did all of my warranty work. Upon arrival to the dealership I could ring out my shirt. It was horrible.
