No power door lock
Old Jun 12, 2008 | 09:08 PM
Aruba1's Avatar
Aruba1
Default No power door lock
I tinted the front windows 2 weeks ago and about a week ago I can no longer lock or unlock the driver side door. The only way I can lock or unlockis manually.All the other electrical switches works fine. The otherdoor will lock and unlock with the switch.
Anyidea how to fix this before I remove the door panel?
Thanks,
Gio
Old Jun 13, 2008 | 11:32 AM
Mayfair's Avatar
Mayfair
Default RE: No power door lock
That's weird. Perhaps the tint is blocking the signal? I dunno.
Old Jun 13, 2008 | 11:43 AM
tiresmoketravis's Avatar
tiresmoketravis
I have tinted and my power locks work fine maybe a plug came loose.my window switch for my back door came off.
Old Jun 13, 2008 | 07:42 PM
Aruba1's Avatar
Aruba1
The other 3 doors will lock when the car exceeds 15 mph (as before) but the driver door will not. Also when using the remote the other 3 doors will lock or unlock but it has no effect on the drivers door. I guess I have to remove the door panel to find what is going on. brhhhh
Old Jun 13, 2008 | 07:45 PM
behindbars's Avatar
behindbars
Sorry to butt in but what tint did you guys go with and how close does it match the backs?
Old Jun 13, 2008 | 07:52 PM
Aruba1's Avatar
Aruba1
I looked at walmart first but theirs is reflective and grayish. I got mine at autozone. I went with 30% to leep it legal and is a close match butI amsure 20% will bea perfect match with the factory tint.
Old Jun 13, 2008 | 09:38 PM
tiresmoketravis
my tint is somewere around 15-20% the side windows are the same as the back glass.
Old Jun 14, 2008 | 12:21 AM
amock's Avatar
amock
I would just pop the switch cover off and pull that assembly out. Then unplug all the connectors and make sure none are corroded. This may solve your problem.
