How much diff fluid...
Old 06-16-2008 | 07:35 PM
04QC4X4's Avatar
04QC4X4
Default How much diff fluid...
do I need to refill the rear differential?
Old 06-16-2008 | 07:36 PM
cumminalong's Avatar
cumminalong
Default RE: How much diff fluid...
Right about 4 qts. Just a bit under and it starts coming out the fill hole.
Old 06-16-2008 | 07:39 PM
04QC4X4's Avatar
04QC4X4
Thanks. That is my project for tomorrow after work.[8D]
Old 06-16-2008 | 08:45 PM
cumminalong
Just did mine again on Saturday. Remember, the cover bolts go to 30 ft/lbs and the fill plug is 24 ft/lbs.
Old 06-16-2008 | 08:49 PM
Bigriver's Avatar
Bigriver
Is it common for the gasket to fail at some point in time. My front cover seems to have developed a small leak, had to top it off alittle the other day.
Old 06-16-2008 | 08:51 PM
cumminalong
It shouldnt. May just need to pull the cover, clean the surfaces and put it back together.
Old 06-16-2008 | 08:52 PM
cumminalong
I mean, yes, eventually it will need to be replaced, but not on an 2006 yet.
Old 06-16-2008 | 09:54 PM
04QC4X4's Avatar
04QC4X4
I can use the black RTV for the gasket right?
Old 06-17-2008 | 06:42 AM
cumminalong
You dont use RTV on the 3rd gen axles. They have reusable gaskets.
Old 06-17-2008 | 12:25 PM
AangryWhiteMan's Avatar
AangryWhiteMan
04QC4X4
Did mine just this weekend. Used Amsoil Synthetic Gear Lube. There is a small indicator on the Diff cover pan showing the fluid level line. The Gasket is reusable but I got a new one (OEM). Needed 3 Quarts at the most. Takes about 1/2 hr to do. You don't need to do this often just check the Level once in awhile. Mine was very clear and clean. The plug has a magnet on it so just check for metal build up. Otherwise don't worry about.[sm=icon_cheers.gif]
Quick Reply: How much diff fluid...
