Gray/White smoke
Old Jun 17, 2008 | 01:55 PM
UpBranchLiner's Avatar
UpBranchLiner
Default Gray/White smoke
When I hammer down on my rig I get a gray/white smoke. This is after it has warmed up and hasnt been drivin hard for awhile. The fuel filter has about 4k on it, air filter is ok, oil prolly needs to be changed. Would a fuel filter do cause that?
Old Jun 17, 2008 | 04:52 PM
DBLR's Avatar
DBLR
Default RE: Gray/White smoke
It sounds more like injector then fuel or fuel filter to me, but then I could be wrong.
Old Jun 17, 2008 | 06:25 PM
04QC4X4's Avatar
04QC4X4
I thought grey/white smoke is unburned fuel. Which would mean a bad injector. I may be wrong though.
Old Jun 17, 2008 | 07:47 PM
JR 06's Avatar
JR 06
white smoke can be unburned fuel or coolant. but since you have a 5.9 it really shouldn't be coolant, so probably an injector.
Old Jun 17, 2008 | 08:48 PM
handymanherb's Avatar
handymanherb
That's just what happens when you baby it for ato longand then stand on it, do it a few times and it will clear up and then start blowing black, ok dark gray anyway.
Old Jun 18, 2008 | 12:55 AM
buckskin's Avatar
buckskin
My 07 5.9 does it on start up, after its warmed up. But blows black down the road. I figured its a sticky injector. When I take it in I am sure the dealer will blame my Edge Juice.
Old Jun 18, 2008 | 01:54 AM
Lead Head's Avatar
Lead Head
I believe grey/white smoke is unburnt fuel, or very partially burnt fuel. It usually happens on older mechanical injection diesels during cold start (<32*F), or when the injection timing needs to be adjusted, or the injector required pop pressure is going down.
A sticky injector or fuel delivery issues could cause that kind of condition on newer common rail diesels I guess.
Old Jun 18, 2008 | 09:31 AM
lilfroger's Avatar
lilfroger
Up do you run a fuel additive? The couple of times I've gotten a ton of white smoke it was a combo of icky fuel and not running PSD.
On the PSD bottle it recommends running a higher concentration if you haven't run it often; to help clean the injectors. Might be all it takes to kick the issue.
