Can I burn #2 heating oil in my Cummins?
Old 06-28-2008 | 12:55 PM
RAMbunkshus's Avatar
RAMbunkshus
Default Can I burn #2 heating oil in my Cummins?
I have about 175 gallons of #2 heating oil that has been stored indoors for about 30 years. It's a clear amber color and smells like, well, heating oil! If I filter it, can I safely burn in in my Ram CTD? I'd sure like to be able to have eight hundred bucks worth of free fuel!
Old 06-28-2008 | 06:17 PM
Bass Hunter's Avatar
Bass Hunter
Default RE: Can I burn #2 heating oil in my Cummins?
#2 heating oil is exactly the same as #2 diesel. The only differance is heating oil is dyed red because there is no road tax paid on it. Just don't get caught with red fuel on road. It's for off road use only.
Old 06-28-2008 | 06:36 PM
Scott91370's Avatar
Scott91370
That must have cost you a fortune back then, what $50??
Old 06-28-2008 | 06:40 PM
RamItOne's Avatar
RamItOne
Its still potent after 30 years?
Hang on to it I'll diesel is 7.25 a gal.
Old 06-28-2008 | 10:14 PM
RAMbunkshus
This stuff isn't even dyed red, it's a clear, amber color. As to whether it's still potent after all these years, that's my main concern. It sure looks & smells OK.
It's been in my basement fuel oil tank ever since I switched to electric heat back in the mid 70's. The oil embargo raised the price all the way up to 65 cents a gallon, so I switched to electric heat.
Old 06-28-2008 | 11:33 PM
NickBeek's Avatar
NickBeek
If I were going to try and run it, I think I would blend it at a low ratio at first. Check mileage and note if the truck ran normally. Then I would slowly increase the ratio and keep tabs on it. If it is bunk you will note a decline in economy, and or lack of power / rough idle. Good luck and let us know how it runs.
Old 06-29-2008 | 12:35 AM
RamItOne's Avatar
RamItOne
Well maybe pour an oz onto a plate and an oz of diesel on another plate and light em on fire, if there's a noticible dif in flame intensity and duration then I wouldnt use it. Or maybe at a 80-20 blend.
Just make sure to mix it before you put it in your truck. Or at least take a 10 gal tank and put 50-50, stir and then pour.
Old 06-29-2008 | 04:20 PM
Tommygunz's Avatar
Tommygunz
Also remember if that oil was purchased in the 70's it is going to have a significantly higher sulfer content
Old 06-29-2008 | 06:32 PM
NickBeek's Avatar
NickBeek
That shouldn't bother an '04.
Old 06-29-2008 | 09:07 PM
jimmyshortz's Avatar
jimmyshortz
To my understanding it would be good for the 04'
