ABS BRAKE NO SPEEDO
Old Jul 7, 2008 | 11:19 AM
blebarron's Avatar
blebarron
Default ABS BRAKE NO SPEEDO
STARTED MY TRUCK THE OTHER DAY.MY ABS LIGHT,BRAKE LIGHT STAY ON
AND MY SPEEDO DOES NOT WORK. GOING DOWN THE ROAD IT BOUNCES A LITTLE
TACH WORKS.TRUCK RUNS FINE 2000 2500 CTD EDGE W/ATT.
Old Jul 7, 2008 | 02:49 PM
shonne's Avatar
shonne
Default RE: ABS BRAKE NO SPEEDO
You (probably) need a wheel speed sensor. About $50 bucks. Had the same issue on my last truck. Hope this helps.
Old Jul 7, 2008 | 02:50 PM
steve05ram360's Avatar
steve05ram360
welcome to DF...
speed sensor on the top of the rear diff is most likely the problem. the symptoms you describe are exactly what happens on the gassers so start there. takes about 10 minutest to swap...
Old Jul 7, 2008 | 03:58 PM
blebarron's Avatar
blebarron
THANKS WILL TRY THIS WEEK
