Performance Review Quadzilla submitted by justviper1
Old Jul 11, 2008 | 05:57 PM
steve05ram360's Avatar
steve05ram360
Default Performance Review Quadzilla submitted by justviper1
Mod: Quadzilla Pulse CM
Truck Specs: 01 Ram 2500 100HP Injectors, Industrial Injection VP44, AirDog 150 gph and Quadzilla Adrenaline with Pulse CM
Source: Discountpowerparts.com
Cost: $235 for Pulse CM, $50 for A-pillar mount, $3 for interior paint
Install Difficulty: 2 can be hard to run the one wire from the Pulse to the adrenaline since the end is a big plug and it doesn't fit down through the dash very easily.
Install time: 30 minutes
performance review: The Adrenaline was amazing but when paired with the Pulse CM it gets better. I can now monitor 4 digital gauges instead of 3 analog ones and at the push of a button can have 4 more. It controls egts, trans temp, boost and much more so that you can define how hard you want to push your truck and when you want it to defuel depending on boost, egts, trans temp, so that you don't break anything. Has built in 1/4 mile test along with 1/8 mile and 0-60. Very easy to use display and works flawless. The Pulse lets you program the adrenaline to the highest settings and then tweak defueling through it so now I also have much more power.
mileage review:I have had it on for 200 mile now and it works great. I have not tested my fuel mileage yet so im not sure if with the new defueling features and the added power whether it will make a difference or not.
_____________________________
