speedometer not working
Old Jul 14, 2008 | 10:56 PM
foxy's Avatar
foxy
Default speedometer not working
i just bought a 1997 2500 4/4 and the speedometer was working.then it just quit working, any help would be qratefull
thanks
Old Jul 15, 2008 | 12:40 AM
chouseal's Avatar
chouseal
Default RE: speedometer not working
Check the speedo gear on the transmission housing... sounds like it might have come loose or rotated so the gears don't contact any more. I can't remember the details, but it's on the driver's side of the tranny. There's a plastic gear in there, changeable so that you can adjust for different size tires, etc. Anyway, the speedo gear housing has to be rotated in a certain orientation to the tranny in order for the teeth to mate up. When I went to change the gear out to account for larger tires, it about drove me mad until I saw the little alignment markings.
If that's not it, I dunno... maybe someone else can chime in with suggestions?
Old Jul 15, 2008 | 08:42 AM
steve05ram360's Avatar
steve05ram360
speed sensor on top of the rear diff housing... is the abs light on as well?
Old Jul 15, 2008 | 05:37 PM
foxy's Avatar
foxy
the abs light was on it had broken wires so i changed them front to back.the light is now off
from what i have read the speed sensor is on the rear of the transfer case not on the rear end is this wright.
does the sensor just push in .
thanks
Old Jul 15, 2008 | 06:40 PM
steve05ram360
humm, the sensor should be on top of the rear diff... somewhere in there they added that sensor to measure speed. if yours does not have one then it'd be in the trans. I havent swapped that one but I'd imagine it'd be held in with a bolt...
Old Jul 15, 2008 | 09:47 PM
foxy's Avatar
foxy
thanks i will change out the speed sensor
thanks again
