Airconditioning problem 2005 Cummins
Old Aug 14, 2008 | 11:10 PM
2005RAM2500's Avatar
2005RAM2500
Question Airconditioning problem 2005 Cummins
I have a 2005 RAM 2500 Cummins, the airconditioner blows hot air on passengers side while drivers side is nice and cold. Both sides have cold air if I select it to defrost? I have serviced the aircon no help have cycled all switches mutliple times?
Would really appriate any help.
Old Aug 27, 2008 | 01:01 PM
Hookem 74's Avatar
Hookem 74
I too have this issue, after you get going for a while, it gets cold on both sides though, at startup it is very bad. I ahve had mine serviced by the dealer, as well as having to do some ifxes myself. Still not sure though.
Old Aug 28, 2008 | 11:01 AM
D's Ram's Avatar
D's Ram
Are all the blower controls not functioning properly? blows out to the feet when defrost is selected, stuff like that? Just happened to mine and I had it at the dealership so I asked them to look at that. after the $100 diagnoses they said a new AC head unit should fix the problem for $230 installed. Searched around a little and found a used one from a wrecked truck on ebay for $35 or best offer. Got it for $25, comes with a 6 month warranty and took no more than 10 minutes to install, VERY EASY! fixed the problem and saved $200. Can't be sure if your having the same problem as me but that's how I fixed it. hope it helps.
