01 cummins power loss
Old Oct 6, 2008 | 08:58 PM
05cumminscrx's Avatar
05cumminscrx
Default 01 cummins power loss
have a dually 01 ho cummins 6 speed, use to have tons of power, has 122000 miles on it now, when ever the truck is pedal to the floor it dont accelerate fast, going up a hill at sixty mph in sixth gear you punch the pedal to the floor wont accelerate, it loses mph, anyone have any ideas truck runs great and has decent power, purs like a kitten. also recently while driving the temp guage dont get very high when you slow down the temp will drop to 160 or lower, any ideas? thanks
Old Oct 7, 2008 | 11:44 AM
92oilburner's Avatar
92oilburner
Air filter? Fuel filter? Lift pump?
Old Oct 7, 2008 | 10:50 PM
mjackson92rs's Avatar
mjackson92rs
downshift.
Old Oct 8, 2008 | 08:22 AM
SpicyJam's Avatar
SpicyJam
Can you give a little more info, like what codes are you seeing? Is this truck bone stock? Any info would be great since my living is made working on all diesels.
Old Oct 8, 2008 | 06:18 PM
05cumminscrx
no codes that i know of, but is it possible to have codes if the check engine light is not on, air filter fuel filter seem to be fine truck is bone stock work truck thanks
Old Oct 8, 2008 | 09:58 PM
SpLaT's Avatar
SpLaT
Like it was mentioned ... "downshift"
or could be your clutch is slipping "use to have tons of power"
"has 122000 miles on it now" might be injectors... 120k miles on original injectors?
"when ever the truck is pedal to the floor it dont accelerate fast" what gear are you in?
"also recently while driving the temp guage dont get very high when you slow down the temp will drop to 160 or lower" could be due to lower ambient tempatures?
"but is it possible to have codes if the check engine light is not on" yes, turn key to "on" position but do not start three times codes will come up on the odometer. But not all codes will show, best is to have the have them read with scan tool.
"air filter fuel filter seem to be fine" when was the last time you changed your fuel filter? I do mine every 10k mile or every second oil change.
I'm thinking, you might have a air leak from turbo to intercooler to intake. Do you have any aftermarket guages.... boost/fuel pressure/ EGT exhaust temp? If so what are they reading?
Old Oct 10, 2008 | 09:47 PM
05cumminscrx
the clutch is not slipping, i dont see the reason why you should have to down shift at 50-60 mph, my 05 will climp a hill at 35 or less in 6th gear and gain speed easliy even all stock. i have no guages.
