Injectors problem
Old Oct 7, 2008 | 02:35 PM
hottrodder67's Avatar
hottrodder67
Smile Injectors problem
ok so i just got a call from a dealer that i have a bad number 6 injector. are the stock injectors on our trucks made from sh*t? what is the best thing to do in the case should i try to find some aftermarket injcs that will not crap out? Anybody know any compnay that makes a good replacment inject? i dont want any high flowing injects or anything like that just good quality.
Old Oct 7, 2008 | 04:18 PM
Bass Hunter's Avatar
Bass Hunter
how old is your truck? How many miles?
Old Oct 8, 2008 | 12:05 PM
hottrodder67
Default injector
its an 06 with 130k on it.
Old Oct 8, 2008 | 03:04 PM
minex's Avatar
minex
My 2007 had only 7000 miles on the odometer before I had to take it in to have one of the injectors replaced. Luckily, it was covered by warranty.
Old Oct 8, 2008 | 05:55 PM
Bass Hunter
I could be wrong but I think thats pretty good milage out of a set of injectors. It seems that is about when people need to start replacing them. Dynomite diesel supposedly makes good injectors but I have no first hand experiance with them.
Old Oct 8, 2008 | 06:56 PM
hottrodder67
Default Injectors/nossles
ok so the dealer told me that my injectors went down the ****ter. what is the diff between nossels and injectors beside the amount. can i take aftermarket nossels and put them in stock injectors whats the best way to solve this problem.
Old Oct 8, 2008 | 09:43 PM
SpLaT's Avatar
SpLaT
Difference between nozzles and injectors is neither will work without the other. The injector is the main body with nozzle at the "tip" of the injector. Fuel flows through the body of the injector out through the nozzle and into the cylinder. At the tip of the nozzle are holes where the fuel is "sprayed" out from. The injector basically allows measured amounts of fuel to flow through and out the nozzle. Same principal of your friendly nurse giving you your flu shot.
You can change the nozzles on your OEM injectors, or you can purchase injectors with higher hp nozzles and send in your OEM as "cores". Best way to go is to send them in, to have the nozzles replaced (this way the they can be tested as well) or you purchase new nozzles and using the "right tool" to replace the nozzles yourself. (special tool is required to hold injector while removing/installing new nozzles)
Old Oct 10, 2008 | 12:31 AM
hottrodder67
Smile Injectors Are On The WAY SWEET!!!!!!
Ok so i did the math and figured out that it is 300 dollars cheeper to buy stock injectors rather than after market. So I ordered so Industrial Injectors 50hp nozzles. I heard i will get close to 3 mpg more with them. Anybody know of this actually happening?
Old Oct 11, 2008 | 08:25 AM
Bass Hunter
Smile
You may get a slight increase if you don't run around using that extra 50 horses all the time.
Old Oct 13, 2008 | 12:43 PM
hottrodder67
Default have a question on new injectors
so i just go tthe new injectors in. do you know if they are suppose to have two small eltirc connetors on them? im wondering if they guy sent me the wrong ones
