what will make my egt run cooler?
Old Dec 11, 2008 | 05:06 PM
jxrowe's Avatar
jxrowe
my fuel pressure is good anyother time..when i idle its 10-13...the only time it gets low is when i turn my chip up to level 5..i cant hold it to the floor because pressure goes to zero and my egt gets anywhere from 1100 to 1250
Old Dec 11, 2008 | 08:40 PM
steve05ram360's Avatar
steve05ram360
sounds normal to me... the higher you go the more fuel gets used dropping the pressure. get a better lift pump and you wont drain the rail. the egt's dont sound to high either.
Old Dec 11, 2008 | 10:57 PM
joey7106's Avatar
joey7106
what are your safety set points on the edge? The edge will de fuel when you hit certain safety points. Egt set point. boost. ext
Old Dec 14, 2008 | 03:23 PM
jxrowe's Avatar
jxrowe
i have my fuel pressure setting to alert me when it reaches 1psi..my etg setting is 1200 degrees when i have it set to alert me...i dont feel comfortable running it when it gets that hot
Old Dec 14, 2008 | 05:50 PM
Bass Hunter's Avatar
Bass Hunter
1200 at the exhaust manifold is just getting hot. 1200 after the turbo is too hot. Where is your egt probe at?
Old Dec 14, 2008 | 05:51 PM
scatpack_69's Avatar
scatpack_69
1200s nothing. Hitting that for a short time wont hurt anything. I bury mine at 1600 just getting on the interstate...its when you SUSTAIN high temps that things start to melt...
Old Dec 14, 2008 | 05:59 PM
Bass Hunter
thats what just getting hot means.
