How much power can the stock tranny hold? (06 auto 4x4)
Old Dec 14, 2008 | 04:36 PM
tn_diesel's Avatar
tn_diesel
Default How much power can the stock tranny hold? (06 auto 4x4)
Ok so Im about to reprogram my 06 cummins and i obviously want the most power i can get, but i dont want to have to rebuild my tranny and upgrade my turbo and stuff. I really like the edge juice with attitude as its adjustable on the fly, shows all the stats of the engine, and has a built in turbo timer. I've heard that any more than 100hp added and ill need to upgrade my tranny. I will be taking this truck to the strip occasionally just for fun with the guys. So any recommendations or suggestions? Thank you
Old Dec 14, 2008 | 05:46 PM
scatpack_69's Avatar
scatpack_69
My stocker lasted ~9 months with Smarty turned all the way; level 9 all the time! 427 at the tires. Edge would be closer to 370-380 or so. And I wasnt what one would call "easy" on it either. It finally started slipping, then slipping BAD when I got on it, and finally the convertor exploded and, thus my built unit.
In all honesty, Id at the very minimum upgrade the convertor. Even better would be convertor/valvebody...you dont HAVE to have a built trans, just those two upgrades will handle more power alot better than the stock stuff will...
Old Dec 14, 2008 | 05:53 PM
tn_diesel's Avatar
tn_diesel
what if i had a built tranny but stock vb and converter? or would it be better to leave tranny alone and do what you said?
Old Dec 14, 2008 | 05:58 PM
Bass Hunter's Avatar
Bass Hunter
I would do what Scat suggested first. The stock tc is only really good for a stock to lightly modified truck and the upgraded valve body is going to increase your line pressure for grater holding force.
Old Dec 14, 2008 | 06:05 PM
tn_diesel's Avatar
tn_diesel
so what if i wanted to just tune the edge juice with attitude to level 5, what should i do first?
Old Dec 14, 2008 | 06:23 PM
Bass Hunter
I run mine on level five with 30,000 miles on the stock tranny while doing it. I just try to go easy on it. When it goes, and it will , I am willing to spend the money on a new tranny. I tow trailers with it and I always turn it down to level 2 when I do that. The power is addictive once you start down this road you will always want more.
Old Dec 14, 2008 | 06:51 PM
tn_diesel's Avatar
tn_diesel
well i dont tow anything, i just bought a diesel cause i love diesels and the power and economy for a truck...what if i just did the torque converter for now and ran it on level 5 how much help would that do?
Old Dec 14, 2008 | 07:33 PM
Bass Hunter
it will help you can do it in stages but you may get a brake on labor doing both at once. the tc is 1-1200$ vb is in the 5-600 range.
Old Dec 14, 2008 | 09:55 PM
moconst's Avatar
moconst
I love my edge, but I dont romp on it much.
Old Dec 15, 2008 | 12:27 AM
scatpack_69
Think of the transmission like a woman. The trans itself is her body/looks, and the valvebody/convertor are her brains...
Ok, so you have a girl, smokin body, but no brains (built trans w/ stock VB/TC). Shes only fun for awhile then she gets old. Plus shes just gonna cost you money in the long run.
Then you have a good lookin girl, not as hot, but a looker, but she has brains (comparable to a stock trans w/ upgraded TC/VB). Now shes gonna be fun longer, cause she can think of new exciting positions. You can afford her more than a Grade A woman.
Now take a smokin hot girl, WITH brains, and you have the best of both worlds (built trans w/ upgraded TC/VB) You might not be able to afford her, but its oh-so-much better if you can.
Help any? And yes, its a reach, but I tried! Hahaha
