cummins and smallblock
Old Jan 21, 2009 | 11:56 AM
atharp318's Avatar
atharp318
Default cummins and smallblock
dose a cummins trans have the same bell houseing as a 318 or 360 gas. im wondering if i can bolt a cummins to a A-833 4 speed overdrive cuz the nv4500 will not fit in the truck that im trying to build and i dont want to go with an auto
Old Jan 21, 2009 | 02:10 PM
Bass Hunter's Avatar
Bass Hunter
I'm not sure but destroked cummins conversions makes adapters. They might be able to hook you up.
Old Jan 22, 2009 | 05:35 PM
scatpack_69's Avatar
scatpack_69
You can make any trans fit in anything. Going in the D150 Im guessing? Guys swap NV4500s into their 1st gen (89-93) Dodges all the time. Same body. So whats not allowing it to "fit?"
Old Jan 25, 2009 | 03:10 PM
atharp318's Avatar
atharp318
the truck that im trying to put it in is a 84 D-150 short bed stepside. the truck is an auto. but i have a 85 D-150 that stick in the humps in the cabe for the trans are different. the stepsides is diferent its not as tall. and i have a rebuilt A-833OD anyways
Old Jan 25, 2009 | 09:05 PM
scatpack_69
So just change the trans tunnel. Cut it out and fab one or go to a junkyard and get one out of a manual truck. I honestly dont know that the A833 will take the torque of a Cummins...maybe for awhile but itd take a crap eventually. The NV4500 is better suited for a diesel
Old Jan 26, 2009 | 01:36 PM
atharp318's Avatar
atharp318
thats what i was thinking but ive seen that trans behind some some hopped up 440s. i would like to use it and put a pistle grip on it. this trans was in a 440 car i would be more causish if it came from a 318 or slant 6 car but im not going all out on the engine this truck is mainly go to be a cruzier it not going to work accually its not set to tow any thing anyways the rear is to high its has 3.2s in it
Old Jan 27, 2009 | 02:02 AM
scatpack_69
You gonna turn up the Cummins any? I realize the 833 is pretty stout behind gassers, but its rare that a gasser makes the torque a diesel does, and thats whats gonna break stuff....if the diesel is left stock, your around 400 some-odd ft.-lbs tq. Turn it up even a little and you could easily be well over 600+. And that will trash a trans in no time. Just food for thought...
