cummins dpf and fuel milage questions
Old Jan 27, 2009 | 12:27 AM
longbowdog's Avatar
longbowdog
Default cummins dpf and fuel milage questions
[B]hello im inquiring about the fuel milage with a 08 dodge 3500 with the 6.7l 6sp manual tranny and 4:10 gears! and also how can the new emissions filter be removed and it not affect the trucks performance? i live in ky so we arent reqd to have state inspections! just didnt know if i could put a str8 pipe on it or not! im farmiliar with the 12v but not this new stuff. any help or advice?
Old Jan 27, 2009 | 01:17 AM
scatpack_69's Avatar
scatpack_69
Your lucky to get 15 on the highway. Ditch the DPF and block off the EGR. Do turbo back exhaust, either straight piped or put in a muffler. The two biggest DPF delete companies are H&S and BADP...theres 5 points in the new exhaust that dont help it much. Theres basically a cat in the downpipe, then the regular cat, then the DPF, the muffler, and then maybe a resonator. So you definately want a turbo back exhaust to get rid of the restriction in the factory downpipe
http://www.rollinsmokediesel.com/cat...elete-kits.cfm
http://www.bayareaperformance.com/
Some of the kits arent code-free andthrow a soft code that will shoe a CEL. Get an Edge Juice w/ Attitude or BullyDof PMT to clear the code on startup. H&S has a new downloader they just came out with that is supposed to be code free and will do the typical things a downloader does (adjust for tire size, add power, etc.) Apparently later this spring they will have a 200+hp tune available. This downloader would eliminate the fooler boxes that existing kits use to fool the computer into thinking the DPF is still in place.
