Help P0516 Batt temp sensor
Old Feb 5, 2009 | 04:12 PM
0ster84's Avatar
0ster84
Default Help P0516 Batt temp sensor
2003 2500 diesel
Is all stock and has been very kind to me. The other day I got "CHECK GAUGES" light with a code p0516 (battery temp sensor low). Took it to dealer...was told diesel tech is 2 weeks out...........Diesel tech heard what was going on and was nice enough to scanned it. He reported everything was normal and cleared the code. Anyway a mile down the road and bing it was 0516. Question is does anyone know what causes this. I have 13.3 volts low and 14.8 volts max. Batteries out and cleaned. Grounds look great. Sensor reads from 20+/-komhs sitting on ice to low 8 komhs sitting in my hand. Short of shooting blind and replacing things or waiting two weeks I am at a lost. Any help would be appriciated.
Old May 6, 2011 | 03:40 PM
McGiver42's Avatar
McGiver42
Default Help P0516 Battery Temp sensor
Greetings Oster84 This was an old post but also need help.
I am having the same problem with my 03 3500 diesel, and was wondering what your outcome or fix was. I did replace the sensor and cleaned and charged up batteries.
Thx McGiver42
Old May 14, 2011 | 08:25 AM
0ster84's Avatar
0ster84
Default Batt sensor
Sorry for the long delay. To make a long story short, I replaced the sensor only to have codes thrown again and again. My problem was happening when outside air temps were low so i wrapped the sensor in some "donk", insulation that is. The problem went away never to return????????? I really don't know if that was the true solution to the issue but it did work........hope this helps.
Old Jun 20, 2011 | 10:27 AM
McGiver42's Avatar
McGiver42
Thanks for the reply, as it turns out also a long story short, my problem was the alternator, replaced with a NAPA rebuilt one and things are good. The sensor was detecting a problem just the problem was with the alternator.
McGiver42
