bd diesel steering question 01 truck
Old Feb 18, 2009 | 07:51 PM
westwoodspeedster's Avatar
westwoodspeedster
Default bd diesel steering question 01 truck
i was looking thu the old summit catalog and seen where bd diesel came out with steering box stabilizer for my 01 truck. it clames that it will greatly reduce the truck from wondering all over the place as around those years were know for. has anyone installed this on there truck and has it helped? its only $200 i mite try it myself
http://www.dieselperformance.com/ind...eview_anchor/4
Old Feb 18, 2009 | 09:21 PM
GOD RAM IT's Avatar
GOD RAM IT
fix your steering first. this should only be used if all of your steering components are good.
Its not a fix as the companies would like you to believe.
if you have a steering problem it willl not fix it, it will just hide it.
so before you throw money at truck make sure your steering is 100%
my 2 cents. there is money better spent elsewhere.
if my steering was 100%. and I had money to spend a PSC box would be my first choice, then a borgenson steering shaft then a dt trac bar.
speaking from experience. went through lots of steering with my 2nd gen
Old Feb 19, 2009 | 12:44 PM
bloomer89's Avatar
bloomer89
I have been thinking of going this route to tighten up my steering. I don't think I have any steering "problems" other than having loose steering, ie. I can turn the wheel from say 11 to 1 without it moving the wheels. Would this be a real issue I should address or will the steering stabilizer reduce the play? Thanks for the help. I've read so many of these steering threads but haven't concluded whether my steering was "bad" or "normal" for these Rams.
Old Feb 19, 2009 | 12:51 PM
GOD RAM IT's Avatar
GOD RAM IT
thats not normal and you should see if the box is turning and the steering is not or if the steering shft turns and the box doesnt.
the bd steering stabilizer will not fix what you have
Old Feb 19, 2009 | 08:08 PM
bloomer89's Avatar
bloomer89
Thanks GRI,
Sounds like I may need to take it in to get a prognosis on it. I almost wish I didn't know, after hearing about what so many members here had to do to get decent steering.
