Questions about Juice w/ Attitude
You guys are way over thinking this. Unless you have done it, and didn't say. Go into your menu, go to Juice Config, then go to Low Boost Adjst. There you go through each of the stages and choose your fuel load for when the turbo isn't spooled up. I have stage one set to low boost setting 1, but I have stage 3 set to low boost setting 5. In stage three when I jump on it from a dead start you will get the coal black smoke. Just keep in mind as the turbo spools the dark smoke will lessen. The low boost setting isn't there for smoke, it is made there for better throttle response. Hope that helps.
