2006 2500 Rearend
Old Apr 4, 2009 | 01:07 PM
mfelsk1505's Avatar
mfelsk1505
Default 2006 2500 Rearend
i have a 2006 Dodge Ram 2500 dizel and the rearend went out of it at 57,000 miles. What i need to know is what the specs are for seting the thing up mainly what the backlash is and how much movement i should have in the ring gear. im no mechanic but my buddy is so he will be seting the thing up for me. any input would help of if you can tell me what website to go to that would work to.
thanks
matt
Old Apr 4, 2009 | 10:27 PM
Parts/Service's Avatar
Parts/Service
This is for a 11.5
SPECIFICATIONS
AXLE
DESCRIPTION SPECIFICATION
Axle Ratio 3.73, 4.10
Ring Gear Diameter 292 mm (11.5 in.)
Ring Gear Backlash 0.13 - 0.18 mm (0.005 - 0.007 in.)
Pinion Torque To Rotate - New Bearings 1.69 - 2.82 N·m (15 - 25 in. lbs.)
Pinion Torque To Rotate - Original Bearings 1 - 2 N·m (10 - 20 in. lbs.)
Total Torque to Rotate - New Bearing 3.4 - 5.6 N·m (30 - 50 in. lbs.)
Total Torque to Rotate - Original Bearing 2.8 - 5.1 N·m (25 - 45 in. lbs.)
Fill Level - From Bottom of Fill Hole 6 mm (1/4 in.) ± 6 mm (1/4 in.)
TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Fill Hole Plug 32 24 -
Differential Cover Bolts 40 30 -
Bearing Cap Bolts 281 207 -
Ring Gear Bolts 237 175 -
Axle Flange Bolts 129 95 -
Adjuster Lock Bolt 25 18 -
for A 10.5...
SPECIFICATIONS
AXLE
Axle Ratio 3.73, 4.10, 4.56
Ring Gear Diameter 266 mm (10.5 in.)
Total Torque To Rotate - New Bearings 3.4 - 5.6 N·m (30 - 50 in. lbs.)
Total Torque To Rotate - Original Bearings 2.8 - 5.1 N·m (25 - 45 in. lbs.)
Fill Level - From Bottom of Fill Hole 25 mm (1 in.) ± 6 mm (1/4 in.)
TORQUE
Bearing Cap Bolts 165 122 -
Sensor Target Magnet Bolt 7 - 62
