Would a programer cause injection pump failure?
Old May 3, 2009 | 10:43 PM
DOGSRIDE's Avatar
DOGSRIDE
Default Would a programer cause injection pump failure?
On my 06 with programer, exhaust, and CAI. I noticed a fuel smell one day a few months ago. I checked under the hood and noticed the injection pump was moist with fuel, no drips. I called the manufacturer of the programer to see if this was common and they said they never had a problem before. i even told them that the dealer was changing the part under warr. i just didn't want to go thur all the bs and have the new pump do the same. Well guess what ? the day i picked up the truck it had that smell of raw fuel. now its been two weeks and one towing trip of 50 miles and it seems worse. Anyone have advice for me?
Old May 4, 2009 | 10:07 PM
racer9's Avatar
racer9
An '06 doesn't have an injection pump, it's a common rail system. That means a fuel "rail" is connected to all the injectors, is pressurized and an electronic pulse fires the injector.
What is probably leaking is the CP3 fuel pump, which is what pressurizes the rail, or one of the fittings or lines.
Old May 5, 2009 | 09:35 PM
terb's Avatar
terb
Lots of miles could make it leak or just bad luck.
Old May 5, 2009 | 10:24 PM
DOGSRIDE's Avatar
DOGSRIDE
wow. my invoice states:
customer states injection pump is leaking.
found injection pump leaking.
replaced injection pump.
a20 3112
r5191780AA pump.
Old May 6, 2009 | 05:10 PM
Bass Hunter's Avatar
Bass Hunter
Injection pump and fuel pump is same thing just two ways of saying it. Unless ofcourse youre talking about the lift pump which I guess could also be called a fuel pump.
Old May 6, 2009 | 09:01 PM
DOGSRIDE's Avatar
DOGSRIDE
Question were getting off the subject.
will the programmer harm the pump? i looked today for fuel leaks and found nun. the fuel odor increases when you go from stock, towing, performance and then to extreme mode. but when you open the hood there's no smell ???
Old May 7, 2009 | 05:12 PM
Bass Hunter
cp3 pumps tend to weep alittle with age. I would think the programmer could cause it to weep more because you are incresing the fuel pressure in the rail making it push harder.
