EDGE juce w/ attitude
Old May 4, 2009 | 10:25 PM
twiessmer's Avatar
twiessmer
Default EDGE juce w/ attitude
just finished instaling it and wow is all i can say power wise. left with a couple questions though. 1, i thought you could see trans temp with it but it dosent show that as an option. and 2nd question is how mutch boost is to much cuz even with it set at 0 power im setting off the boost alarm pushing 37 psi, thats full throtle of corse but it seems kinda hi what should i set the alarm at ?
Old May 5, 2009 | 12:31 AM
moconst's Avatar
moconst
mine shows trans temp, if your pushing 37 on your boost somethins up. I usually only get to 25-30 tops.
Someone else will chime with a better response, I could be wrong.
Old May 6, 2009 | 05:25 PM
Bass Hunter's Avatar
Bass Hunter
Mine also shows trans temp. You do have an auto trans right. My truck also hits 37 pouds of boost no problem. When you get that high your getting way past the efficancy of the stock turbo. I set mine to alarm at 35 and defuel at 35.
Old May 7, 2009 | 10:06 AM
slammedsporty04's Avatar
slammedsporty04
The edge juice w/ attitude does not show trans temp. Off the edge website this is what it will monitor.
Your Attitude monitor allows you to monitor the performance of your engine’s vital engine components and output values. The following parameters can be displayed on the main Attitude screen (maximum 4 at one time):
• Backdown %
• EGT (exhaust gas temp)
• Engine Load %
• RPM
• Speed MPH
• Boost
• Engine Temperature
• Barometric Temperature
• Throttle position
• Transmission Lock
• Transmission Slip
• Intake Temperature
And your stock turbo can easily handle that much boost. There are a lot of guys with boost foolers that are pushing over 40 lbs. of boost with the stock turbo.
Old May 7, 2009 | 11:42 AM
GOD RAM IT's Avatar
GOD RAM IT
05 and older CTDs will not show tranny temp with out a sending unit in the tranny. the 06-07 ones can by connecting to the data link or OBDII
Old May 10, 2009 | 10:58 PM
twiessmer's Avatar
twiessmer
ya i emailed edge and they cleared it up for me. the site i bought it off of claims all kinds of stuff that it dose not do. when i do the 1/4 mile times im only getting like 15 sec with 100% back down i thought it would do better than that. i have not done any upgrades to the trans... am i driving on borrowed time i have 70000 on the truck. but i don't know what the trans can handle in stock form.
Old May 11, 2009 | 04:12 PM
Bass Hunter
The trans can handle 40-60 horse over stock. Alot depends on your driving style if youre doing boosted launches and burnouts it isn't going to last long. If you are going to drive on level 4-6 alot than you are going to need some upgrades.
Old May 11, 2009 | 06:05 PM
garrettg84's Avatar
garrettg84
you guys make me want a programmer, but i know i'll blow out my tranny if i get one =(
