right, stop,turn,almost dead
Old Jun 15, 2009 | 07:23 PM
jason_blocker's Avatar
jason_blocker
Default right, stop,turn,almost dead
Well hello again need more help.My 2006 2500 has the factory towing package and brake controller. This weekend I hooked up to the boat after rewiring the boat trailer lights and replacing the trailer lights; {I knew my trailer lights needed replacing} but my right stop turn signal wasnt working, come to find out its the truck. I checked the 7pin connection and the 4 pin and both are the same. On the right stop turn I dont get a brake or turn signal just a steady 7volt DC reading even with everything off. All the lights on the truck itself work fine. Is this an issue anyone else has had or heard of. I have not called Dodge yet, because I have had so much luck with this site and its members. Please any help would be great I hate wiring and may have to take it to someone I only know the simple stuff..
Old Jun 19, 2009 | 02:03 PM
donnyv's Avatar
donnyv
I'm having similar problems with my 2004 Ram 2500. I checked some fuses and changed one and it worked... ...for maybe 5 seconds. I'm not an expert, but I gave it a look and nothing seemed missing or out of place. Since I don't want to tear stuff apart I won't be able to put together, I'll have to find time to get it up to the dealership.
Anyone else have any idea what it could be?
Old Jun 20, 2009 | 06:45 AM
jason_blocker
check out this post and forum it may help you. It tells me to go to the dealer my truck is too smart for me.http://www.dieseltruckresource.com/d...trailer+lights
Old Mar 17, 2010 | 11:49 PM
05Ram1500's Avatar
05Ram1500
Yeah I got the same problem with a 06 ram 2500 diesel. The right side trailer signal and brake light circuit does not work. Is there a recall on this? What the hell is the ipm? Where is it and how much is it to replace?
Old Mar 18, 2010 | 12:08 AM
pizzo's Avatar
pizzo
No recall its not a safety item Maybe a tsb on it that is about it... IPM integrated power module. If you need one might want have it checked out first at a dealership I know its hard to say but its worth the little extra money vs buying it and not be it... after that Might want to check out CoalTrain he can get some crazy stuff like that cheaper then anyone I know..
Hope that helps Pizzo
Old Mar 18, 2010 | 01:19 PM
dodgetrucker75's Avatar
dodgetrucker75
check all your fuses under the hood, each circuit is on seperate fuse for the trailer plug, but it will probably blow again if you hook the trailer back up, check the wiring on your trailer
