Strange Throttle Problem
Old Jun 26, 2009 | 09:15 PM
soniclm's Avatar
soniclm
Default Strange Throttle Problem
I have a 01 Dodge and I have been having a problem for at least a couple months, I have a Holley Blue pushing like 14 psi idling and it maybe goes down t 7 psi here and there. Its all basically stock except the exhaust and Edge Attitude with Juice. I usually drive it in 1:3 but the problem seems to be worse when the chip is up. It drives fine except for the unlocking and locking of the torque converter here and there but I know how to fix that, but when I like get on it, I have it at like 70% throttle and the rpms are still then it revs ups and kicks in. Its not lag because I know the difference. I had the injector pump replaced last year, replaced the cam sensor, MAP sensor, and the TPS sensor in the past within 2 years. There arent any codes under engine and ABS using a snap on solus scanner but I didnt check the body. The only code I have had lately is 734? for the torque converter circuit since I have a switch on it. If anyone has any ideas what they may think it is, that would be great.
Old Jun 28, 2009 | 09:15 AM
racer9's Avatar
racer9
Don't understand your question. Are you saying the motor revs up, then the truck takes off? Does it do it rolling at speed, or from a dead stop?
Might be a trans issue. Either the TC is slipping, or it is shifting down too low, then shifting back up.
Old Jun 28, 2009 | 11:24 AM
soniclm's Avatar
soniclm
when I'm driving and I like turn my chip up, I can give it like 70% throttle then a sec or tow later, it revs up and goes
Old Jun 28, 2009 | 06:13 PM
racer9's Avatar
racer9
What does the fuel pressure do, when it happens? Are you seeing a large puff of smoke?
It sounds like you're trying to dump more fuel than the motor can take, until the turbo spools. Do you have a boost fooler? Does it do it if you're in the throttle, or just from a low rpm?
Old Jun 28, 2009 | 07:48 PM
soniclm's Avatar
soniclm
fuel pressure is fine, not large puff of smoke, I just have a clamp on the wastegate, just does in when i give it alot of throttle
Old Jun 29, 2009 | 07:19 AM
Bass Hunter's Avatar
Bass Hunter
Throttle position sensor maybe?
Old Jun 29, 2009 | 07:24 AM
soniclm's Avatar
soniclm
I have changed that out twice
