cold air/warm air
Old Aug 10, 2009 | 07:57 PM
ezbassin's Avatar
ezbassin
Default cold air/warm air
I have a 2004 2500 diesel that blows cold air on the drivers side and warm air on the passenger side. What is the problem and how hard is it to fix?
Old Aug 11, 2009 | 07:32 AM
triton's Avatar
triton
sounds like you have the infamous vent door issue. It gets stuck and the only way to fix it is to pull the whole dash a part. It's a lot of work but, can be fixed
Old Aug 11, 2009 | 09:54 AM
srountreeoo7's Avatar
srountreeoo7
Do a search on google or cummins forum there is a way to fix it without tearing the whole dash apart.
Old Aug 11, 2009 | 05:26 PM
ezbassin's Avatar
ezbassin
I have been searching forums but haven't found much on it yet. I will check google. Does this happen on the Ram 1500? Do both trucks share the same components?
Old Aug 11, 2009 | 10:21 PM
cumminnotstrokin2's Avatar
cumminnotstrokin2
Just had mine fixed cost $680.00 at the dealer. Glad I bought the extended warranty
Old Aug 12, 2009 | 06:27 PM
ezbassin's Avatar
ezbassin
I found the answer. Getting the system recharged has worked for some people. If the doors are broken you can order them from Heatertreater. They also show you how to check the doors to see if they are broken and how to change them out.
http://www.heatertreater.net/
Old Aug 13, 2009 | 02:10 PM
12valveman's Avatar
12valveman
the system is low..... this is a tell tale sign that it is low only part of the evap is cooling have it checked...
Old Aug 13, 2009 | 06:06 PM
Grr287's Avatar
Grr287
my a/c seems to blow steam out periodically while it's on. idk why
