rear drive shaft support bearing
Old Nov 5, 2009 | 01:31 PM
dixiedodge7369's Avatar
dixiedodge7369
Default rear drive shaft support bearing
does anybody make a better then stock rear drive shaft support bearing??
replacement is a dealer only part. but i drive hard and ive gone throught all 3 u joints and now the support bearing at 50K. i just got the factory one today it is a sealed bearing. im gonna try and see if i can install a grease zerk so i can atleast pump some grease in from time to time but id like to see if anyone makes a better one??????
Old Nov 5, 2009 | 02:13 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
They make a 1 piece alum drive shaft that gets rid of the carrier bearing. They only work on 4wd models. 2wd have a cross member that gets in the way. They are about $450 if you look around.
Factory part numbers for 4WD:
Auto: 52123220AB
6spd: 52123162AA
