Help!!
Old Nov 17, 2009 | 07:29 PM
zdawg801's Avatar
zdawg801
Default Help!!
Alright bout to be buying a new dodge cummings looking in the 22k price range so Im not buying a new one as you can see. I want a crew cab 4x4 .. should I get a manuel or auto idk whats better Im going to be making it a fast car and hitting the track with it. If I do get manuel can I make shifting better? Help any sort of help as to wat I should look for will help greatly Im new to this...
Old Nov 20, 2009 | 08:22 PM
pizzo's Avatar
pizzo
Auto is what you want. First thing to do when you get it home. before you add HP trans and Gauges to it FIRST. then what ever engine mods you want to do go ahead and get them. The transmissions are ok as long as your stock or little amounts of horsepower no more then 40hp area after that the trans is able to fail without warning. Suncoast or Goerend is the best transmissions around. if you need any parts check out our vendor section. Some in their have Just diesel shops and that is all they deal with. that will be your best bet.
Old Nov 21, 2009 | 01:45 AM
dodgetrucker75's Avatar
dodgetrucker75
what's a cummings
anyway, an auto will get down the track faster but lots of $$$ to do so, a manual will be a lot cheaper and more reliable than the auto to put the power through, all depends on what you want to do
Old Nov 22, 2009 | 10:50 AM
zdawg801's Avatar
zdawg801
alright appreciate the help
Old Nov 23, 2009 | 11:42 AM
2005RAM2500's Avatar
2005RAM2500
I would go for a full billet auto, from either suncoast or goerend...They both have a excellent reputation and will build strong trans for your application.
