first gear slip
Old Dec 12, 2009 | 11:21 PM
NoBallZ59's Avatar
NoBallZ59
Default first gear slip
So after my truck warms up first gear seems to slip and the truck doesn't start to move till I'm around 2000rpms. When it's cold it moves fine around 1200 or so. But other than that the truck drives fine. Shifts done up through the gears and down shifts fine too. Not sure what this means. Hoping it's not that first is on it's way out. But if so what can I do?
Old Dec 12, 2009 | 11:25 PM
dodgetrucker75's Avatar
dodgetrucker75
oh no... is this the truck you just bought? the only thing i can think to start with is a fluid flush and filter change, could be the filter is getting cloged, but also with the pan off, you will be able to see if there is any pieces in the bottom... other than that it could also be a converter issue too
Old Dec 13, 2009 | 12:12 PM
pizzo's Avatar
pizzo
once you change the oil its takes ATF+4
guess not it wont link it http://www.doghousediesel.com look for DIY articles and trans flush
Old Dec 13, 2009 | 12:43 PM
NoBallZ59's Avatar
NoBallZ59
ahh yeah it is.....
well i did some testing today and found that its not first that seems to be the problem. whats happening is when i start the truck warm or cold and put it in drive it goes fine. no slip. as i drive up the road and it goes through the gears it shifts fine. then when i come to a stop it only goes down to second. even if i manually put it in first. could this just be a shift solenoid?
on a side note i checked the fluid today and found that it was dirty and a quart low. topped it off and plan on doing a filter/fluid change this week.
anyone have thoughts on this?
Old Dec 13, 2009 | 01:47 PM
pizzo's Avatar
pizzo
Originally Posted by NoBallZ59
ahh yeah it is.....
possibly I'm not the greatest person in the world about our transmissions the model number is a 48RE... I thought the shift solenoid was bad it would haunt from gear to gear and not know what gear to be in. But I am not sure I don't know much about the trans in our truck
We have the same trans I have a 2004.5 3500
Old Dec 13, 2009 | 06:44 PM
dodgetrucker75
You are getting second gear starts.
It's most likely the governor solenoid in the trans. I would replace the pressure transducer at the same time since they are side by side.
It's an easy fix in the driveway and you must get the parts from Dodge.
Old Dec 13, 2009 | 07:58 PM
NoBallZ59's Avatar
NoBallZ59
well i got the same answer from you and someone else on cumminsforum so im going to go ahead and say this is most likely my problem. so i just ordered the two parts from transmissionpartsusa.com. good price and dodge parts! much better then the dealership. should have them by next weekend. ill swap things out and let people know how things work out. thanks for the imput
